2390 Views 9 Replies Latest reply: Sep 7, 2011 6:07 PM by greghutch RSS
dirckb Just Startin' 8 posts since
Oct 7, 2007
Jan 8, 2011 4:48 PM
Toneport UX2 models no longer work
I have Windows 7 64, and a UX2 with the full complement of model packs.  The line 6 stuff was working, but I had to replace the motherboard, and now
none of the model packs work.
* Uninstalled & Reinstalled, Drivers 4.1.1.7, Pod Farm 2.02, Monkey 1.34 and Gearbox 3.72
* No error from Pod Farm, but Gearbox says:
     DSP failed to load model correctly.  You may not hear the selected model.
     Reason: (Code 80007104) Failed write to firmware.
Other stuff I've tried:
* Authorize "refresh" from monkey
* using a different USB port on the computer
* using a different USB cable
* transferring the model pack off and onto the device again
* moving the ".aet" file from a computer that works (Windows XP machine with no problems)
The motherboard that worked was a Gigabyte P55-USB3
The new motherboard that doesn't work is an MSI P55-GD80
Not having the model packs is a serious drag.
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Jan 17, 2011 4:53 PM (in response to dirckb)
    RE: Toneport UX2 models no longer work
    Sorry for the delayed response here. We are pretty backed up here in support and are doing our best to answer questions as fast as possible.
      Thanks for following up on what your workaround is. If Line 6 Monkey was detecting your device when connected to your motherboard via USB, then is certainly should have seen your packs, especially after a refresh.
      Not sure why that didn't work but I'm glad you're up and running.
      Line6Miller
    Mar 28, 2006
    Jan 25, 2011 3:15 PM (in response to dirckb)
    I honestly do not think there is another solution for your issue other then the PCI card you installed.
      There are so many possible variables from computer to computer that the same symptom may be resolved through different means from one machine to the next.
      Line6Miller
    Mar 28, 2006
    Jan 25, 2011 3:45 PM (in response to dirckb)
    Thanks for your feedback. Please be sure to submit it below as well:
      http://line6.com/company/contact/productfeedback/
      I will also log your inquiry as a quality concern.
      Line6Miller
  • davpat Just Startin' 2 posts since
    Jan 29, 2007
    Sep 5, 2011 11:10 AM (in response to dirckb)
    Re: Toneport UX2 models no longer work
    I have exactly the same problem. I bought new laptop ESPECIALLY to work with my UX2 and everything is like dirckb said.
    Gearbox don't work. POD farm do, but i can't practise with lessons in GPO...
    Did you find solution?
  • greghutch Just Startin' 1 posts since
    Mar 31, 2006
    Sep 7, 2011 6:07 PM (in response to dirckb)
    GuitarPort UX2 & Windows 7 32 bit don't play well together. I have installed all latest drivers and still opening GuitarPort puts CPU so high PC is almost locked up. Stop the process and CPU is fine. Start GuitarPort again and CPU goes to roof. I see this has been an issue for a couple years now but I do not find where it has been addressed. I have seen many users doing their best to find a good work around but I think Line6 should fix their driver.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
