3611 Views 14 Replies Latest reply: Apr 19, 2011 10:20 AM by fingerscaraballo RSS
mikedbb Just Startin' 9 posts since
May 18, 2008
Jan 12, 2011 2:08 PM
Harmonizer/Pitch shifting with Pod HD
Hi, I was wondering if someone could answer me this?
I've read that the Pod HD series have a harmonizer and pitch shifter effect.
Without playing in a particular key can you set it for instance for 3 semi tones up or down?
So no matter what fret you're holding the Pod will produce the note 3 frets/semi tones up regardless of the key
Sorry for my ignorance with this issue.
Help would be great!
Cheers!
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Jan 12, 2011 2:20 PM (in response to mikedbb)
    Re: Harmonizer/Pitch shifting with Pod HD
    You could do that with the Pitch Glide effect.  The Smart Harmony always will adjust the harmony per a scale, so to shift at a consistent interval, you'd want the "dumbness" of the Pitch Glide.
    Mar 26, 2007
    Jan 12, 2011 2:22 PM (in response to mikedbb)
    Smart Harmony is always relative to a key.  But you could use Pitch Glide to set a constant pitch difference
  • desso Just Startin' 116 posts since
    Mar 3, 2007
    Jan 13, 2011 11:03 AM (in response to mikedbb)
    If I were to play in a live situation (I just play in my studio), with the HD500, I would absolutely run stereo into 2 power amps/cabs if at all possible.  Of course keeping in mind positioning for the audience's ears.  I love the stereo effects.  I also love 2 different amps panned L/R.
        Mar 3, 2007
        Jan 13, 2011 11:43 AM (in response to mikedbb)
        Yeah, the studio environment opens tons of opportunities.  Sometimes I'll lay down numerous takes with effects trails going to opposite sides, of course ping pong delays, stereo reverb trails, etc. Another really good technique is to record two takes (rhythm) playing the exact same setup and trying to play both exactly alike. There will be minute differences that when panned hard L/R will produce a really nice full sound. I think the recording/mixing process takes as much creativity as the actual playing.
        • meambobbo Iknowathingortwo 1,702 posts since
          Dec 13, 2007
          Jan 13, 2011 12:38 PM (in response to desso)
          That's only part of why double tracking sounds so rich.
          You have to think separate takes can't possibly be in phase.  Take an A note at 440 HZ.  Do you really believe you have enough control to make the sound wave start precisely in sync with the one you've already recorded.  No chance.  You might be in rhythm, but you're out of phase.
          Playing the two out of phase tracks through the same speaker causes distortion.  So you pan them to avoid this.  But when they meet in the air and in mix in your ears and brain, your brain basically interprets this as a reverberation, and it adds a spacial dimension to the sound .  Yet it has no lingering decay, so its nice and tight.
          At least that's my theory.
Bookmarked By (1)
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
