2378 Views 8 Replies Latest reply: Nov 5, 2012 5:09 AM by DanyalZafar RSS
jrluciw Just Startin' 21 posts since
Nov 13, 2009
Jan 13, 2011 6:42 AM
Using HD500 with Logic Pro
Has anyone had any exprerience with this?  I tried it for the first time tonight and Logic Pro Crashed each time I tried to assign Line6 to my s/w instrument track.  Actually the plug in didn't show as being an HD 500..just Line6...I think Gear Box.
Thanks
John
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Jan 13, 2011 6:54 AM (in response to jrluciw)
    Re: Using HD500 with Logic Pro
    well there's your problem.  you can't use gearbox or pod farm with your POD HD.  I'm assuming you have the plugin versions and they're looking for a license on the Line 6 hardware, which isn't gonna work...
    to start with, create a new project or whatever in logic, and just add the POD as your audio input device.  can you record a track just from your POD without using any other plugins, etc??
  • ricksox UberGuru 11,600 posts since
    Mar 28, 2006
    Jan 18, 2011 10:32 AM (in response to jrluciw)
    RE: Using HD500 with Logic Pro
    Hello,
      Are you trying to use the Gearbox or POD Farm plug in or are you simply trying to set up your HD500 as your main input/output device in Logic?
      Also, what version of Logic are you using?
      What operating system is installed on your computer?
      Line6Miller
    Mar 28, 2006
    Jan 19, 2011 9:26 AM (in response to jrluciw)
    In regards to your crackling audio issues, you may want to make sure your software is up to date.
      I noticed in your account that you have not downloaded the latest drivers 5.12 for your Mac as well as updated the firmware on your POD to 1.20.
      Run Line 6 Monkey and make sure everything is up to date.
      Also, you may want to try changing your sample rate settings as well as your buffer slider in the Line 6 Audio MIDI Devices control panel and Audio MIDI Setup.
      Line6Miller
    Mar 28, 2006
    Jan 20, 2011 10:31 AM (in response to jrluciw)
    Thanks for following up with me John and I am very happy to hear that our support has met your expectations. There are not many of us here in support so at times we do get backed up but we do our absolute best to respond to inquiries as quickly as possible.
      Again, thank you for your kind words and let us know if you have any more questions.
      Line6Miller
    • DanyalZafar Just Startin' 1 posts since
      Nov 5, 2012
      Nov 5, 2012 5:09 AM (in response to ricksox)
      Re: RE: Using HD500 with Logic Pro
      Hi. Just bought my new hd500 and am trying to figure out the best way to record my guitar in Logic pro. How do i get a better sound quality? through usb into my mac or by the adding the hd500 into the chain of my guitar going through my avalon 500 through my appoggie rossetta 800 into logic via cables?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
