Jan 16, 2011 4:27 PM
X3 live pilotare voce e chitarra- X3 live voice and guitar in the same preset
Like (0)
Ciao, sto cercando di creare un preset dove nel tone 1 dovrebbe uscire la chitarra e andare alla mia testata e quindi poi alla cassa e nel tone 2 la voce in diretta nel mixer. Mi sembra di aver settato tutto nella maniera corretta ma ho sempre un piccolo rientro della chitatta nel mixer, qualcuno mi sa aiutare?
Grazie, Carlo.
Hi, i'm trying to create a preset where in tone 1 there is guitar (directed to my head and cabinet) and in tone 2 the voice (directed to the mixer). I think that's everything ok but a little "feedback" of the guitar always enter in the voice channel :-(
Someone can help me? Thanks, Carlo.
Is it possible that the mic is simply picking up some sound from your head/cab through the air?
I think no, because it happens also when the tone 1 (guit) is muted or when the volume of my head is turned completly off... It seems like you cannot exclude/separate completly the output of the tone 1 inside the tone 2, so a little percent of the sound always goes in the tone2.
Please describe your setup in detail:
- your physical Inputs and the selections on the X3 Inputs page for both Tones
- your physical outputs/routing, and the selections on the X3 Outputs pages for both tones, for both Studio / Direct Mix and the 1/4" Live Outputs, including pan settings.
Ok, here is my setup:
PEDALBOARD:
Guitar in: send
Live out: return (LEFT)
Guitar: head
Mic: Mic in
Direct out (LEFT): mixer
INPUTS PEDALBOARD ON DISPLAY:
Guitar: tone 1
Mic: tone 2
Enable/Disable global control???
OUTPUTS 1/4 INCH:
Mode: stack pwamp???
Tone 1 pan: left
Tone 2: mute
STUDIO/DIRECT MIX:
Tone 1: mute
Tone 2 on pan: left
Match studio direct
I hope to be clear and exhaustive, otherwise ask me what you need.
Thanx a lot, C!
Try backing both your Pan controls from full left by one tick/position. I seem to recall that there is some bleeding between Tones in the X3 when pan is set to 100%. Try it at 99%.
Ok, thanx i'll try in the next days and update you as soon as possible. Bye...
+1 to nickmattocks' suggestion. Also, make sure you have the latest firmware version installed on your POD.
Line6Miller
No, is an old version but what happen to my presets in case of updating? Is possible a complete reset with the risk to loose all my sounds/patterns?
B: how can i update my firmware?
Thanx a lot...
Use Gearbox to save your existing presets to your computer before updating the X3 firmware. Then you can use Gearbox again to reload the saved presets after updating.
Ok, thanx a lot. I'll try in the next days...
