1866 Views 5 Replies Latest reply: Jun 11, 2011 6:35 PM by Giax1974 RSS
trorie Just Startin' 5 posts since
Jan 31, 2011
Feb 7, 2011 9:46 AM
M9 parameters glitching...
I love my M9, but I'm having some interesting issues that I'm hoping someone can shed some light on.
Occassionally, when I am using the tap tempo, rather than simply adjusting the bpm, it is actually changing the displayed note value to something random (i.e. I have it set at a quarter note, then after a few taps it randomly switches to a dotted quarter, or any other random value). Also, adjusting certain parameters, even when I'm in setup mode, causes other parameters to randomly shift (i.e. I'm adjusting the the mids and suddenly the gain jumps to a random value, or I'm adjusting certain options in setup mode only to watch as others are randomly shifting as well). I do have an expression pedal plugged into the pedal 1 port. It especially happens when the looper is activated.
Anyone else experiencing this? I reinstalled the firmwire, but seem to still be experiencing issues. Any help would be much appreciated. Thanks!
UPDATE: I removed the expression pedal, and I'm still having issues. I adjust certain parameters and watch as others are randomly adjusting as well (i.e. dialing in a note value only to watch the mix/feedback settings shift as well),
  • tommasi Iknowathingortwo 627 posts since
    Sep 3, 2007
    Feb 7, 2011 12:02 PM (in response to trorie)
    Re: M9 parameters glitching...
    It almost sounds as if the pressure you apply to the footswitch is causing the unit to read some "jittery" movements of the pots. If you're not already in that mode, I suggest you configure your pots to the "relative" behavior, in the setup screens.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Feb 10, 2011 2:09 PM (in response to trorie)
    RE: M9 parameters glitching...
    It's sounding more like an internet hardware issue at this point; if numerous firmware reinstalls hasn't changed the symptoms and you've tried setting the pot behavior to "Relative" mode, it's deeper than the software level.
      The next step is to get your unit to the nearest Authorized Line 6 Service Center for a repair tech to diagnose the issue and provide you with a solution: http://line6.com/support/serviceCenters/
      Regards,
      L6Perry
      Sep 3, 2007
      Feb 10, 2011 9:58 PM (in response to Kneehow)
      Re: RE: M9 parameters glitching...
      Definitely... One thing is the occasional 'pot jitter', and another is a complete parameter freakout! Time to get the unit looked over by a service center, I'm afraid...
      • Giax1974 Just Startin' 54 posts since
        Dec 6, 2007
        Jun 11, 2011 6:35 PM (in response to tommasi)
        Dude!!! I have the same issue, I thought I was the only one on earth with this issue, I just posted: http://line6.com/community/thread/65675
        I am gettign very ****** off, my M13 is acting like it's alive and parameters switch, vibrate shiver, shift, mine is happenning only with the EXP peda (which I use a lot), so right now I cant use my exp pedal, and this suck. It happen on both EXP pedal 1 and 2, when I unplug it, it behave well.
        I can make a full heel/toe, when I try to setup expressions, I can't go 100%, it goes randomly, it shifts, jump, etc.
        Please let me know if you got an answer for this, for me is very difficult to find a Line 6 support center, I live in Lima Peru, and also lost all my M13 documents when I moved here.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
