2707 Views 3 Replies Latest reply: Apr 28, 2009 11:49 AM by Kneehow RSS
Fig5000 Just Startin' 2 posts since
Apr 20, 2009
Apr 20, 2009 7:36 AM
Tone Edit controls don't work
I'm using a Pod 2.0 Pro with a mac g5 PC with OSX 10.5.6. I've installed Tone Edit version 3 and it sees the Pod ok but the tone controls don't connect to the sound. Tweaking them doesn't change anything. I had the same problem with the old Tone Edit recently, which is why I upgraded. Any thoughts?
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Apr 21, 2009 2:47 PM (in response to Fig5000)
    Re: Tone Edit controls don't work
    Hello,
      Have your downloaded the latest Line 6 software directly from the website?  Have you installed the latest drivers for your USB/MIDI device directly from the manufacturer's website?  Try this first, as well as removing all non-essential USB from your computer, being sure to connect your MIDI-USB cable directly to the computer (not into a hub).  If you are still having problems, try your POD with a different computer with the latest software installed.  If you are still having problems, your POD will need to be serviced.
    Line 6 Monkey Installation and F.A.Q.
    http://line6.com/community/docs/DOC-3898
    Line 6 Edit FAQ
    http://line6.com/community/docs/DOC-3783
    Java /Vista errors with Line 6 Edit and Workbench
    http://line6.com/community/docs/DOC-4497
    Product Repair
    http://line6.com/community/docs/DOC-4285
    Line6Andy
    Please be sure to award Helpful and Correct points to community members who respond with helpful or correct answers!
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Apr 28, 2009 11:49 AM (in response to Fig5000)
    Just to double-check: you should've downloaded the Line 6 Edit Version 3.01.0
    Installer (Released 1/1/07).
    You might also try different MIDI cables between the POD Pro 2.0 and the MOTU interface. Also, try disconnecting the MOTU from the front USB port of your Mac and connect to a rear direct port. Please do not connect through a USB hub, as this is not a supported connection and will probably give incorrect communication between device and host computer.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
