Feb 16, 2011 1:54 PM
HD 500 + DT50 some presets have no sound
Like (0)
Hi.
i have HD 500 and 2 DT 50 for stereo.
i use the d6link conection with mic cable.
the presets that are just fx with no pre amp dont have sound at all.
( couldnt find a post about this..)
also it amazing the noise that the amp does when it switch presets. my good.
imagine on a live gig....
i am so sad , bacause the sound i really good! really really good!
will this be fixed? hope so..cause i have 2 DT 50....
also the hd 500 as the same problem when changing presets.
will this be fixed.
thank you so much.
greatings from portugal!
pedro
When you select "No Amp", you're bypassing the HD500 and engaging the DT50 channel B preamp. So if the volume controls on the DT50 channel B are down, you won't hear anything! You can select the Topology, Class and Pentode/Triode on the amp itself to set it up they way you'd like.
As far as the "burst" of noise that happens when you switch presets, this is a bug that has been noted by Line 6, Hopefully it will be fixed with a software update soon. It is worst when you have the volume pedal less than 100%. If it's a problem for you keep your volume pedal up all the way when building your presets.
