1040 Views 1 Reply Latest reply: Feb 22, 2011 8:04 AM by jaycon11 RSS
Oskk Just Startin' 2 posts since
Feb 1, 2011
Feb 19, 2011 12:20 PM
How to add Pod Farm 2 effects to a dry signal?
Im pretty exhausted to look for the answers from the net after all the searching, so ill just ask here. So i have already discovered how to record separate dry and wet signals to my recording program(Live 7.0.10, Reaper, ect.)mainly im using Adobe Audition 3.0. Could someone tell me precisely how can i apply my Pod Farm 2 tone setups to my previously recorded dry signal?
Any advices or answers are highly appreciated, thanks.
  • jaycon11 Just Startin' 5 posts since
    Nov 25, 2007
    Feb 22, 2011 8:04 AM (in response to Oskk)
    Re: How to add Pod Farm 2 effects to a dry signal?
    hi.  in audition (a session track, mind you), with the "main" tab in the forefront, click on the "fx" butting at the top of the tab.
    expand the track witdth size where the wav file is displayed and you'll see the fx window emerge on the left (in the box where the mute, solo, and record buttons are located).
    in the fx window, right next to "fx", there is a button with a circle broken by a vertical straight line.  click on this to activate the effects.  in the window immediately below it, click the arrow.  this will show all effects options.  pod farm should be listed inder "vst".  once pod farm engages, there will be a window at the top to choose pre-set sounds (you can manipulate this to choose settings you've created, once you know what folders you can access from here).
    hope this helps.
    best,
    - j
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
