Mar 9, 2011 10:07 PM
Still do not understand how to connect the HD 500 directly into my amp Return Valve
Like (0)
Guys,
I have the HD 500.
I would like more information on how to jump on my tube preamp and connect directly to the HD 500 on Return of the amp.
1) There is, in fact, only those two ways to skip the pre-amp and use only the return of the amplifier (taught in the "POD Connections, Routing and the 4 Cable Method")? Incidentally, there is no other way?
I ask this because the store I bought my HD, the seller made a more complexade to skip the pre-amp, not so simple as those taught in the "POD Connections, Routing and the 4 Cable Method".
Help me here ...
Thanks
If you want to connect the POD HD 500 so that it bypasses the preamp section of your amp, you can simply connect the HD 500 to the FX Loop of the amp.
Is this what you are trying to do?
Are you unclear on how you want to connect the HD 500?
Thanks,
David
Line 6 Customer Support
