1951 Views 9 Replies Latest reply: Nov 15, 2011 2:32 AM by Goochster RSS
Goochster Just Startin' 38 posts since
Feb 18, 2010
Mar 22, 2011 9:20 AM
Recording with Spider Valve 112 mkII
Hi
I'm new to the forum and have recently purchased a Spider Valve 112 mkII, and would like to get into home recording and am looking for some advice on the best way of going about it.
I'm assuming the easiest and cheapest way would be to go from the direct out on my amp to the line in (mic) socket on my PC using an XLR to 3.5mm jack cable but suspect there would be severe latency issues with my PC's in built sound. Another way I assume would be to purchase a usb sound card and connect the amp's direct out to the sound card and then sound card into USB.
I know I'll need to purchase some sort of home recording software like cakewalk to record and mix my tracks but what I really need to now is the best way of getting my tones into the PC for recording/mixing etc.
To be honest I'm a total recording noob so if anyone can lend me the benefit of their knowledge on the best way to go abou this I would be very grateful.
Many thanks!
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Mar 22, 2011 10:15 AM (in response to Goochster)
    Re: Recording with Spider Valve 112 mkII
    welcome.
    you are correct that your built in sound card would likely give you high latency.  in itself that's not an issue if you're only recording your guitar track, but if you want to jam to a backing track that's playing on your PC, and record to that, you'll find it's a pain, although still doable.
    something like the POD Studio UX1 would work well, as you can connect the DI direct to the mic input on the UX1.
    that said, you may fine there's a larger range of tones available in POD Farm 2, which is free with the POD Studio UX1.  you can also buy tone upgrades with model packs... do a bit more research on that though before you buy, as there's lots more to it.
    as for a recording package, some are easier to use than others, and a good one to get you started is riffworks T4 (google it) that's more of a looper with drum backing tracks.  or Reaper is a full DAW, and is very cheap.  something like $60 for a full license (if you don't make a lot of money from your music that is).
    there's lots of info about that already around so do some googling.
    also come back with any specific questions.
    Rowbi
        • nprenger Just Startin' 82 posts since
          Jul 25, 2007
          Mar 23, 2011 6:54 PM (in response to Goochster)
          You would connect the direct out on your amp to the mic input on the UX1 using a standard microphone cable. The UX1 should eliminate any latency issues because its headphone jack monitors your playing without having to be processed by your computer first. I have the UX2 and have had good results both using the direct out and using a microphone.
          Your signal would probably be recorded in mono since that's how it will come out of the amp, but most recording programs will allow you to split it into left and right sides if that's what you want to do.
          nprenger
                • SSstormtrooper Just Startin' 94 posts since
                  Jan 19, 2011
                  Nov 14, 2011 10:53 AM (in response to Goochster)
                  Does the little Logitech system sound good? If so then they will be okay for a moderate volume level for monitoring.But if you're going to cheat and start cranking the volume then I'd say a larger speaker set-up might be better.
                  For a small bedroom setup I have an old set of B&W 200 series bookshelf speakers with a Pioneer Elite Home Theater amp and it does the trick nicely.Also a good set of AKG headphones.Old Kef speakers downstairs.Excellent big B&W in the Home Theater system,of course the bigger more expensive ones are great but the small ones are fantastic for lower level listening/monitoring as well.
                  Paradigm Titans are a great bookshelf speaker as are their older micro series.George Martin(Beatles producer) used big behemoth B&W Matrix 801's for studio monitoring.If money is tight I'd stick with the Logitech for now.I have an old Altec Lansing all-in-one thing hooked to another laptop in another room and it sounds really good.
                  But if you want a richer,fuller sound I'd go with the powered Alesis or some Tannoy or similar specifically designed studio monitors.Or you could also go with an old 2 channel stereo amp and speakers as mentioned above.
                  One good thing about the Alesis is that they are magnetically shielded whereas some full range home theater speakers aren't(some are,alot of bookshelf size are).
                  I hate to be all over the map but their are so many different choices and possibilites.
