Mar 26, 2011 10:32 AM
Pedal 2 in Wha mode?
Like (0)
Push down on the pedal very hard (toe down position), you'll need to be standing up to put enough weight on it to engage the switch.
When I push on the pedal it is still the same. I get only volume control on the pedal 2. In the edit software It is not possible to switch between the both pedals. Strange....
Have you tried the factory presets, like Son Of Plexi that has the Wah already setup?
The WAH dind't function.But on effect 1 in the edit software it is possible to make a choice between pedals (example Pitch Glide). That is working. Otherwise I tryed all the presets and all the same. No WAH choice. I hope there is an answer or software update because I am using my pod400 on my hand and on my desk. So that's the reason I like to control the Wah on the floor.
Here's a snip from the HD400 manual that I think explains things....
Optionally, you can connect an additional Expression Pedal (such as the Line 6 EX-1) to the PEDAL 2 jack on the back of POD HD400. Once connected, the WAH mode is automatically assigned to the on-board Pedal, and the VOL assigned to Pedal 2. You’ll see both the WAH and VOL LEDs lit to indicate this state. Note that you can still assign either the WAH or VOL mode to the Pitch Glide effect, and it will be controlled by the individual, assigned pedal.
Seems you cannot assign Pedal 2 to WAH.
Thanks for clearing that up silverhead, I totally misunderstood the question ![]()
Thanks for your support! I read also the manual from the HD500. It's the same. Maybe something for line6 to upgrade this in the edit software.
timowens wrote:...
HaHa - wish I could say I'd never done that!
I know - you're just distracted and anxious to get updating your HD500 bugs thread after v1.22...![]()
