3504 Views 6 Replies Latest reply: Apr 3, 2011 9:25 PM by 1oldguitarman RSS
moetsch123 Just Startin' 5 posts since
Mar 3, 2011
Mar 28, 2011 1:59 AM
Technical: FBV "Long Board" Instructions
Hello.  I have recently purchased a FBV "long board" controller but I need the manual.  I have looked on your web page for a manual but none seem to cover the long board with all of its buttons and features.
I am using it with my POD 2.0.
Can you point me in the right direction?
Thanks,
Matt
Mar 22, 2011 4:54 PM in response to: moetsch123
RE: FBV Longboard Instructions
Quick question: if you take a look on your POD 2.0 by the CAT-5 jack, does the silkscreened label say "FBV Pedal" or just "Pedal"?
Matt (me) writes:
It says FBV Pedal.  The pedal seems to work I just don't have any instructions specific to it and can't seem to find any on this site.  Advice?
Thanks,
Matt
  • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
    Jan 24, 2007
    Mar 28, 2011 3:28 AM (in response to moetsch123)
    Re: Technical: FBV "Long Board" Instructions
    What the longboard can do is covered in the manuals for each device rather than in a dedicated FBV Manual.
    I haven't looked at the POD 2.0 manual but I have the Vetta II and longboard and in the Vetta II manual there is a section titled "Using Your Feet" that covers what the longboard does.
    Go to the manuals section and get any POD 2.0 manuals you can find and you might find what you're looking for there.
    Cheers,
    Crusty
  • 1oldguitarman Just Startin' 29 posts since
    Mar 10, 2008
    Apr 3, 2011 11:00 AM (in response to moetsch123)
    Hey, Moe.  There is a procedure that gets your two FBV pedals properly calibrated.  I recently purchased a used FBV Longboard as a backup to my 3 year old unit and noticed that the Wah function sounded terrible, way too tinny.  I had discovered this procedure 3 years ago and printed a hardcopy.  It was on this site back then, but today I couldn't figure how to get back to it, so here it is below:
    CALIBRATING FBV LONGBOARD
    1. Put both pedals at halfway - on FBV press the following 3 buttons simultaneously: AMP1, AMP2 and Pitchshift/Tremelo.  This clears the current settings
    2. Press AMP1, AMP2 and Delay together - the FBV display should show a letter (L)eft denoting which pedal you're doing, then several sets of 3 digits:  001-255 actual position of pedal,  -001-127 normalized position of pedal (re: midi),  - Min    -Max      Move pedal to full heel-down, then toe-down hard to click the switch.  Pedal is set
    3. Press AMP1, AMP2 and Modulation together - display should change to denote (R)ight pedal now being set
    4. Press AMP1, AMP2 and Delay together - same as #2 above now for the right pedal
    5. Power the FBV down and plug it back in
    6. READY!!!
    Hope this helps!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
