1488 Views 2 Replies Latest reply: Apr 18, 2012 9:39 AM by broacherx RSS
bshirah Just Startin' 1 posts since
Dec 28, 2008
Mar 28, 2011 6:09 PM
Flash Memory/HD400 Edit Issues
I have a HD400.  I tried to update the flash memory using line 6 monkey but the it will not update.  There is a question mark in front of the words "flash memory" although the update available is 1.20.  The HD400 setup shows version 1.03.  The HD400 Edit will not recognize the device.  Line 6 monkey says that I'm connected.  It let me update the USB Firmware and is recognizing the HD400.  Any help is appreciated.
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Mar 29, 2011 9:55 AM (in response to bshirah)
    Re: Flash Memory/HD400 Edit Issues
    Fire up the Monkey with the HD400 connected.
    Install the Driver from the Monkey menu.
    Once the install start to download disconnect the HD400 from the computer.
    Follow the driver installation
    plug in your HD400 when you are prompted to
    You could also go to the download page and download the driver and install it...The important thing is that the HD400 MUST BE DISCONNECTED from the PC when you start the driver install...If you leave it connected, most likely the driver will not install properly...
    restart the Monkey and see if you can update the firmware...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
