1835 Views 3 Replies Latest reply: Apr 12, 2011 2:26 PM by Kneehow RSS
Giax1974 Just Startin' 54 posts since
Dec 6, 2007
Apr 5, 2011 10:58 AM
Routing M13/tube amp/effects chain correct?
Hi guys, I just want to verify that my M13, tube amp and effect chain setup are correctly:
Guitar>compressor(philosopher king) > octave(pog2) > distortion (GT500) > M13 INPUT (FX1 and FX2) > M13 Send > AMP IN > AMP FX SEND > DELAY (DMM) > M13 RETURN (FX3 and FX4) > M13 OUT > AMP RETURN.
Attached is a figure diagram.
My questions are:
1- Does my setup is correct? my effect
2-What would be the benefit of adding a volume pedal? Now I control volume with then guitar knob.
3- Is there a simple method to use all this effects? Or this is just right?
4- I had a doubt placing my distortion pedal, as I also use the amp distortion channels, this amp has a clean, a vintage and a high gain setups that I footswitch between them, for some reason I doubted it has to be placed right after the M13 fx2, in case I put a filter synth type effects on fx1 or fx2.
Also I doubted if it can be right after the  amp pre distortion, as I use this pedal to add more gain and boost my amp.
5- I am using  my amp reverb, where is placed at this point the reverb?
Thanks for your help as usual!
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Apr 11, 2011 11:03 AM (in response to Giax1974)
    Re: RE: Routing M13/tube amp/effects chain correct?
    1. Your setup looks fine, in terms of routing "logic".
    2. Volume swells might be easier for you to obtain than with the volume knob on your instrument (but I've played with guys who can do that very well). Also, you have the option of inserting a volume pedal in different places of your chain, whereas the guitar's volume knob is always "pre" everything.
    3. Based on your setup, you'll be doing a lot of "tap dancing". But there's really no way around this if you're trying to use all those pedals.
    4. You should always consider putting any gain-related pedal BEFORE the tube amp's input. Where in terms of inbetween the other pedals is entirely up to you (and your ears).
    5. I think the reverb of most amplifiers exist at the very end of the amp's architecture, after the Effects Return jack, but before the power amp tubes. You'll need to double-check with the amp manufacturer on that to be sure.
    Dec 26, 2007
    Apr 12, 2011 2:26 PM (in response to Giax1974)
    No problem! Happy sonic-sculpting...
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
