Apr 14, 2011 8:20 AM
Wah, what am I doing wrong?
Like (0)
I can't seem to properly put on a wah using the LCD to edit the Pod HD 500
I enable one, and it's always on. If I step on the pedal, it'll change from a "stuck" wah to a sweepable wah, but if I turn off the expression pedal (toe click) i'm back to a stuck wah sound instead of turning the wah off.
If I enable a wah, and turn it off, when I step on the expression pedal it doesn't do anything. It stays off.
If I enable a volume pedal first then the wah, I'm back to problem 1.
If I go into the pedal assignments and change the control to Exp 2 or something, nothing really changes.
How do I put a wah on the patch in off mode, and have the ability to turn it on using the expression pedal toe switch?
Almost sounds like you are setting up the wah properly to be controlled via the expression pedal, but you are not setting the FS control to turn the wah on and off itself using the toe switch..
Have you tried pushing and hold enter while the Wah is selected in the FX block and making sure it is set to "EXP TOE SWITCH"?
No I don't think I've done that. I'll give that a shot!!!
Honestly, that's kind of annoying that I have to tell the wah how to work. Seems like it should default to those settings then let me change them if needed.
Here's how to fix it:
That should work. If it doesn't, select the wah block and select "None", then reload the wah into that effects block, and try the steps above again.
