4270 Views 21 Replies Latest reply: May 29, 2012 5:18 AM by toneman2121 RSS
Texxxxx Just Startin' 368 posts since
Aug 13, 2006
Apr 18, 2011 6:00 PM
New DC-3g Power Supply A Bit Pricey, IMO.
Geez....$50....$60 after tax and shipping...
Come on, now...this power supply is worth maybe $15-$25 at the most...certainly not 10% of all the components that go into a HD500.
These won't work on the HD's, but they are built to do the same thing ( I know, different mA and plug sizes):
http://www.musiciansfriend.com/navigation?q=dc+power+supply
...and they are much cheaper.  I really don't think the Chinese are charging more than a few cents more to manufacture the L6 version.
There...I said it....
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Apr 18, 2011 6:20 PM (in response to Texxxxx)
    Re: New DC-3g Power Supply A Bit Pricey, IMO.
    I imagine that the retailers will be able to sell this as well and perhaps it won't be quite as much. One thing to remember, though, is that this is a truly universal supply that comes with multiple adapters for use all over the world. When you consider what the price would be for getting different adapters and/or converters, it doesn't seem that bad.
      • JB1973 Just Startin' 604 posts since
        Apr 19, 2008
        Apr 19, 2011 3:01 PM (in response to Texxxxx)
        wow that is a bit strange price for what you get. The cord was 1/2 worthless to begin with due to the length. I was surprised not to at least see a comment that they made it longer. I ended up having to rubber band a extension cord to the power cord because it kept coming apart and has been a trip hazzard. Now its probably a fire hazzard lol.
  • gunpointmetal Just Startin' 171 posts since
    Dec 27, 2010
    Apr 19, 2011 3:07 PM (in response to Texxxxx)
    If they're not gonna offer a longer corded version, at least sell us a freakin cable extension or something. And $50 is too much for a power supply with that short of a cord, even if you can plug it in on the moon.
    • tim1953 Just Startin' 112 posts since
      Mar 20, 2011
      Apr 19, 2011 5:24 PM (in response to gunpointmetal)
      It's just another example of them screwing you when ever they get the chance.
      Just like when you buy a drill at Sears for $30 and you need a replacement battery and they want $27.50 for one.
      Or the $50 weed wacker who's replacement battery Cost $40
      They should supply the vasoline when they bend you over...........
  • fingerscaraballo Just Startin' 172 posts since
    Feb 22, 2007
    Apr 20, 2011 9:55 AM (in response to Texxxxx)
    There are other power suplies that will also work make sure you read the manual and do some research, on older post there were a few posted that work and are longer and cheaper
    hope this helps
  • markbrid Just Startin' 99 posts since
    Sep 28, 2010
    Jun 23, 2011 5:04 AM (in response to Texxxxx)
    Disclaimer:  The following has NOT been tested with any Line 6 product, and the connector/polarization may not be right.  Do NOT order this part, it is just for a price comparison.
    That being said: 9VDC 2A wall switching power supply, with autoswitching line input?  Under $17 at Mouser:
    Clearly the Line 6 supply is a switcher, but keep in mind that in the past switchers have been frowned upon for use in critical audio circuitry (although that might have changed with newer supply designs).  It's also possible that Line 6 designed the supply filtering and unit shielding with their specific power supply in mind, and a cheaper switching supply might introduce noise into the audio.  There may be other issues as well.  The original Line 6 supply could have many advantages.
    However I would not be too worried to use a good linear supply with the HD, but it will be a lot bigger/heavier than the Line 6 supply, probably more expensive, and would likely not have autoswitching input voltage.  I'd probably go with a linear supply if I had to replace mine.
    Message was edited by: markbrid; removed wrong part number
    • ozbadman Gear Head 1,474 posts since
      Apr 17, 2008
      Jun 22, 2011 4:57 PM (in response to markbrid)
      Do not use an under-rated power supply on any electrical product. The POD HD will still try to draw up to 2.5A from this 2A supply. The wiring of the power supply will not be rated above the 2A current and you could start a fire.
        Sep 28, 2010
        Jun 23, 2011 5:03 AM (in response to ozbadman)
        Whoops, my bad, just looked at the Line 6 supply; it's rated at 100-240VAC 1A 50-60Hz in, 9VDC@3A (27W) out.  This one would be more in line, a bit higher at $21:
        http://www.mouser.com/ProductDetail/Condor-SL-Power/CENB1030A0903B01/?qs=sGAEpiMZZMtpkqKkT5w3uoo7j8gXTa77CgON2gBfOTQ%3d
        Again I have NO idea if this will work, but it does represent a similar type product for pricing considerations.
        FWIW, here's the data sheet for the M8H-27US08R supply (model number of the Line 6 part):
        http://www.autec.com/pdf/M8H-20%2827%29%2830%29US.pdf
        I suspect the Line 6 part is custom built for them from this basic product line, with a non-standard semi-locking plug.  That would explain the higher price.
        • toneman2121 Gear Head 1,985 posts since
          Oct 15, 2006
          Jun 23, 2011 6:41 AM (in response to markbrid)
          "Again I have NO idea if this will work, but it does represent a similar type product for pricing considerations"
          i don't see why it wouldn't work, electricty is electricity. as long as it's rated the same and the plug fits. thanks for the bargain hunting. if my power supply goes, i know where to get another.
            Sep 28, 2010
            Jun 23, 2011 7:11 AM (in response to toneman2121)
            Just be advised that power supplies have different noise characteristics, and behave differently under certain conditions.  I would not at all guarantee this supply would not cause noise issues with the HD.  Also, the connector on the supply might not fit the HD.  If you do try it and it works, please let us know.
        • aishwaryakg Just Startin' 1 posts since
          Aug 12, 2011
          May 29, 2012 4:49 AM (in response to markbrid)
          The 27W from mouser has center pin positive... but i rewired it and it works absolutely fine.
        Sep 28, 2010
        Jun 23, 2011 7:15 AM (in response to ozbadman)
        You have a point, but most switching power supplies like the one in the link are designed to tolerate continuous output short circuits with no fire, smoke or damage.  What would most likely happen if that supply was used would be under some conditions it would shut itself off, or go into an on/off oscillation.  I doubt it would cause any fire.
        However there are other supplies that could get hot and cause problems, so your advice is good for all power supply types just to be sure.
  • Santuzzo Just Startin' 296 posts since
    Mar 20, 2009
    Jul 5, 2011 3:16 PM (in response to Texxxxx)
    I have to agree.
    Here it is about 30 Euro....for a plain, simple power supply????
    I thought that must be a mistake, so I e-mailed Thomann and asked them about it, but they said no, it is really that expensive.
    Unbelievable......
  • PremiumJones Iknowathingortwo 238 posts since
    Mar 29, 2008
    Jul 6, 2011 7:14 PM (in response to Texxxxx)
    I left my power supply at the drummers house last week. I found a 9V DC adapter that had the right plug, but only supplied 800mA.
    It worked for about 30 minutes, then just died. No fire, not even a spark or some smoke...
    I then did surgery on a PS2 Slim power supply (rated for 8.5V DC and up to 4.65A, my meter says its putting out more like 8.75V) to attach the plug from the now-dead 9V PSU, and that worked great for several days. Didnt even get hot.
