1899 Views 1 Reply Latest reply: Apr 26, 2011 4:34 PM by Line6Don RSS
Unterreiner Just Startin' 1 posts since
Apr 24, 2011
Apr 24, 2011 6:33 PM
Multitrack on Garageband
Hello, I need help figuring out how to record two instruments at once on different tracks using a toneport UX2 and Garageband 3. I know its an old version but I'm hoping someone still knows how to use it. I was running two microphones with 1/4 outputs into the "normal" and "pad" inputs on the front of the toneport and a usb out into my macbook. Though only the normal input was producing a signal. I had two tracks set to record but they were both only recording the one mic. How can I get one channel per mic?
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Apr 26, 2011 4:34 PM (in response to Unterreiner)
    RE: Multitrack on Garageband
    Hey Unterreiner,
      First off you will need to configure which inputs you would like to listen from your UX2.
      -Launch the Line 6 Audio-MIDI Device menu located in your System Preferences.
      -Select the Inputs & Recording tab.
      -Select which input source you would like to listen to here.
      Within GarageBand:
      -Create two tracks.
      -Assign the input of track 1 to desired output of the UX2, and do the same for track 2.
      I hope this helps.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
