3823 Views 24 Replies Latest reply: Jun 2, 2012 3:14 PM by nfkn17 RSS
amhogan05 Just Startin' 12 posts since
Mar 21, 2007
Apr 24, 2011 9:09 PM
Windows 7 Pro 64 will not recognize PODxt Live
Hi all,
I am hoping that sompne has solved this particular issue in a way that I can use.  Windows 7 Professional 64 cannot find my PODxt Live after installing Monkey or Gear Box. I've been throught eh forum and more and while I am not the only one who has this problem, none of the current solutions work for me.  Here is what I've done and observed.
  • I've tried this on two machines, both with USB 2.0 ports
  • The PODxt does not show up in the Device Manager
  • The Found New Hardware Wizard never appears
  • I am using the versions of Monkey, drivers, and Gear Box available on the website as of today, 4/24/2011
Thanks for the help.
Andrew
    Jan 27, 2010
    Apr 26, 2011 3:34 PM (in response to amhogan05)
    RE: Windows 7 Pro 64 will not recognize PODxt Live
      Does the POD XT Live function normally when not connected to the computers?
      Are you connecting directly to the computers or using a USB hub?
      Thanks,
      David
      Line 6 Customer Support
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    Apr 29, 2011 8:52 AM (in response to amhogan05)
    Re: Windows 7 Pro 64 will not recognize PODxt Live
    So the Monkey can not see it?
    Have you tried another USB chord?
    Feb 20, 2007
    Apr 29, 2011 10:08 AM (in response to amhogan05)
    I know it's a pain, but if it were me, I would try to confirm it still communicates properly on an XP machine, this may at least rule out it is a problem with the USB on the xtPro.
    I am running a PODxt (not pro) with Win 7 64, I originally had BSOD issues which were related to a USB filter, I doubt that is your issue, but if you have an AMD machine it can't hurt to try.
    http://www.smartdongle.com/remove-amd-usb-filter-driver-ati-catalyst-install-manager
    Also, have you tried uninstalling all the Line6 drivers and running the driver installer outside of Monkey without plugging in the Pro until instructed?
    And temporarily disable your anti-virus and firewalls before re-installing.
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Apr 29, 2011 10:15 AM (in response to amhogan05)
    Hey amhogan05,
      If you have already tried using different USB cables, please make sure to use every available USB port on your laptop as well. In addition, please remove any additional unnecessary USB devices when troubleshooting.
      If trying all the available USB ports does not help you, then you might want to try rolling back to the previous versions of drivers.
      Please uninstall the current drivers using the Line 6 Uninstaller located at:
      C:\Program Files\Line6\Tools
      Once you have successfully uninstalled the current drivers.
      Go to our Downloads page and download Version 4.0.2.7 of the Windows 7 drivers and install them.
      http://line6.com/software/
      I hope this helps, please let us know your results.
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    May 3, 2011 12:24 PM (in response to amhogan05)
    Removing all other USB devices and testing all of the USB ports on your computer is the best thing.
      IF Windows does not recognize the hardware, I suggest isolating the problem by testing with a different computer.  The result of this should tell you if it is a hardware problem on the POD that needs to be serviced:
      http://line6.com/service_centers/
      Regards,
      Line6Hugo
    Apr 8, 2007
    May 4, 2011 9:09 AM (in response to amhogan05)
    1.  Yes.  The driver file is L6PODxt_x64.dll and it should be located in the C:/Windows/System32 folder
      2.  You must be the administrator of the computer to properly install and use the software on your computer system.
      Regards,
      Line6Hugo
    Mar 14, 2011
    May 5, 2011 9:42 AM (in response to amhogan05)
    Hey amhogan05,
      Monkey will not display the installed drivers if it cannot detect and connect to a device. So as Line6Hugo mentioned, you can verify the driver is installed by checking the file location:
      The driver file is L6PODxt_x64.dll.
      In addition you mentioned you have tried this on a second computer without success. What operating system was this second computer running?
      Thanks for your feedback.
    Mar 14, 2011
    May 6, 2011 4:18 PM (in response to amhogan05)
    Hey amhogan05,
      We have recently released a new driver, please go to download and install it and give it a try:
      Please let us know your results, thank you.
    Mar 14, 2011
    May 9, 2011 9:23 AM (in response to amhogan05)
    Hey amhogan05,
      It is very strange that the driver installer is not installing the .dll into the correct file location. Did you try running a search to find it? Maybe it was somehow installing to a different file location.
      Are you running any sort of anti-virus/spyware/firewall software of any kind on this computer? This could also be preventing the installation from completing correctly.
      Have you been able to test the POD XT Live with another computer that is not running Windows 7?
  • johnnylife Just Startin' 1 posts since
    Oct 22, 2011
    Oct 23, 2011 9:37 PM (in response to amhogan05)
    hey Lin6 don im having the same problem it wont install
  • krisscross44 Just Startin' 1 posts since
    Feb 16, 2010
    Dec 12, 2011 3:19 AM (in response to amhogan05)
    Having the same problem with my pod xt on windows 7, will not recognize device.
  • nfkn17 Just Startin' 1 posts since
    Jan 9, 2010
    Jun 2, 2012 3:14 PM (in response to amhogan05)
    thread bomb.
    i had all these issues with podxt and winders 7. always got device cannot start in device manager.
    moved usb cable to rear and it fired right up and windows loaded the driver. works good now.
    dell tower machine windows 7 pro all updates current
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
