1471 Views 8 Replies Latest reply: Apr 27, 2011 4:10 PM by Line6Don RSS
MarcelV91 Just Startin' 16 posts since
Apr 12, 2011
Apr 25, 2011 6:56 AM
Cannot connect with monkey.. + Looper problem
Hi all,
I am trying to update firmware using monkey, but everytime i try to login/connect (not the connection with the pod, that works ok, but the connection with Line 6 Online/Server) i get the same error.
This is what`s in the error:
Login failed.
Make sure you are connected to the internet.
Reason: (Code 8000204E) Sockets: Timed out.
I tried the following to fix it:
- Set proxy on/off in browser (we use to have a internet proxy, but with en without the proxy i get the same error)
- Set firewall/virusscan on/off.
It is really sad i am not able to update my Pod HD500 now, so i really hope someone has a fix or workaround fot this issue..
Is it maybe possible to install the firmware without monkey?
**EDIT** Just noticed something else, if i have proxy enabled, i get the message: 'proxy authentication required' (Only if i click direct the 'Check for updates' button) I do have an username and password for the proxy, but i can`t set it anywhere in Monkey..
O, btw another issue according to my looper: recording, playing and overdub works fine. Only one thing doesn`t seem to work, to overdub with different tones/patches. I have searched the web and manuals for this, but cannot find it. Everybody sais i just have to exit looper mode by pressing the looper switch, but when i do that, each change i make in my patch, or when i select another tone/patch from the list i get the same applied to my recorded part. . Is is something with Pre/Post? I know that there are others with this issue, but none of what other suggested works for me. I have to say i am using an quit outdated firmware 1.02? i thought, so maybe it is fixed in an newer firmware? If this is the case, then i still have the major problem of not being able to update my firmware because monkey cannot connect with my account.
Hope you can give me some help.!
Marcel
    Mar 26, 2007
    Apr 25, 2011 10:44 AM (in response to MarcelV91)
    Re: Cannot connect with monkey.. + Looper problem
    You can perhaps get the latest firmware from the Download section - see the link at the top of the page.  You can then use Monkey to update the firmware from File - with File being the file you downloaded.   I would however download and installe the latest version of Line 6 Monkey (1.35) before attempting the update.  You can get the latest versions of Line 6 Edit, HD500 drivers and anything else useful the same way if you have no other option.
    I'll come back to the looper later..... once you have the update issue out of the way.  One thing at a time, so it doesn't get confusing...
    Nick
        Mar 26, 2007
        Apr 25, 2011 1:45 PM (in response to MarcelV91)
        If the HD500 appears in Monkey as it should if you have installed the drivers, then if you ignore all the login stuff and click the section marked  Flash Memory, you should see the option to update from file as a button on the right.
        Nick
            Mar 26, 2007
            Apr 27, 2011 2:01 PM (in response to MarcelV91)
            If you place the looper in the PRE position it records the un-effected guitar signal completely dry and then if you change the amp model or FX settings those settings will affect what you've recorded in real time as the loop plays back.
            If you place the loop in the POST position it records the guitar with the current amp model and FX settings in place and changing these settings after you have recorded the loop will not alter the characteristics of what's already been recorded.
            I'm not really sure what you mean by 'only half the sound quality stays'.  Sorry.  I have just tried a simple looped recording on my HD500 to double check what I am telling you, and when i record in either Pre or Post mode the audio quality and level of what I record remains the same as when it was recorded.
            Nick
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Apr 27, 2011 4:10 PM (in response to MarcelV91)
    RE: Cannot connect with monkey.. + Looper problem
    Hey MarcelV91,
      Please post a sound sample of the problem you are experimenting with the POD HD500 looper. In addition, please provide us with detailed step by step instructions on how to setup the POD and encounter this error your are experiencing. Thank you in advance for your feedback.
      Thanks again nickmattocks for all of your help.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
