1609 Views 9 Replies Latest reply: Mar 17, 2013 10:47 AM by rasmus15951 RSS
XeroJager Just Startin' 13 posts since
Sep 9, 2009
Apr 30, 2011 4:17 PM
Issue with UX2, constant Buzzing
hey there
I have a Line 6 UX2 running on the newest pod farm, and newest stable Drivers that line 6 has to offer
My setup is:
UX2 going going into computer via USB
Computer using AMD Turion 64X2 TL-60 2.00Ghz
2.5GB RAM
Widnows 7 32Bit
Audio out from Headphone Jack to M-Audio Studiophone AV30 monitors
So here's my issue:
My Setup worked fine, 100% with no hitches whatsoever, worked in every USB port, etc etc, but as of recently i've been getting alot of buzz
from my interface.
Upon plugging it in, nothing, no buzz, i can run applications and listen to music just fine. I turn my POD Farm on, and suddenly buzz like CRAZY
I plug my guitar in and it sounds like there's already some gain put onto the guitar, even with a dry signal, so i thought it would just be the noise
gates being off/not set correctly, this was not the case. I did everything i could, and nothing seemed to work.
Turning POD Farm off, the buzzing still persisted and nothing stopped it unless i unplugged the interface and went back to my onboard sound card, rending the UX2 useless.
i DID notice that when it was on, i would go to reach for any knob on the UX2, or even the headphone input, it would buzz even more
could be a grounding problem?
What do you guys have to say?
Thanks
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    May 4, 2011 10:26 AM (in response to XeroJager)
    Re: RE: Issue with UX2, constant Buzzing
    Hey XeroJager,
      Make sure that you are connecting your POD Studio UX2 directly to a USB port, and are not using a USB hub, extension, or keyboard of any kind. Preferably connect it to a USB port on the back of your computer. Make sure to disconnect any unnecessary USB devices as well when troubleshooting.
      Please make sure to reference our USB Audio Troubleshooting:
      http://line6.com/community/docs/DOC-4282
      Windows 7 consumes a lot of your systems resources, optimizing Windows 7 can increase your performance. Some Windows 7 Optimizations can be found at the links below:
      http://line6.com/community/docs/DOC-2085
      http://www.pcworld.com/article/172351/optimize_your_windows_7_pc.html
      You also mentioned that your computer is using a AMD chipset. It has been know that AMD chipsets and windows 7 have experienced USB problems. For information regarding removing the AMD USB filter, please follow the link below:
      http://line6.com/community/docs/DOC-2215
      I hope this helps.
    Jan 27, 2010
    May 6, 2011 4:45 PM (in response to XeroJager)
      Is the computer a laptop? If so, does it still hum if you are running off of the battery?
      Thanks,
      David
      Line 6 Customer Support
    Mar 14, 2011
    May 9, 2011 9:38 AM (in response to XeroJager)
    Hey XeroJager,
      Please double check your guitar and guitar cables and make sure that they are not the source of the buzz on their own.
      In addition, please try adjusting the buffer size of the UX2. To do so, launch the Line6 Audio-MIDI Device Menu located on your control panel. Try increasing the buffer size, lower buffer sizes can create buzz/distortion if the computer is not powerful enough to stream the audio fast enough.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    May 10, 2011 2:02 PM (in response to XeroJager)
    Based on everything that you've tried and posted here, yes. I assume every single component (USB port/cable/host computer) remained constant except for the UX2 versus your older GX.
    If so, then yes probably a hardware issue inside the UX2.
    I have created a support ticket for you regarding this situation.  A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
      http://line6.com/account/tickets/view/
  • jalenbuer Just Startin' 1 posts since
    Feb 28, 2013
    Mar 4, 2013 12:34 PM (in response to XeroJager)
    Re: Issue with UX2, constant Buzzing
    I am also having an issue with buzzing. Whenever I strum there is an annoying buzz/crackle that follows it. I checked all my guitar jacks, and all my cables. I even bought a new cable to make sure. Can someone help me out?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
