872 Views 2 Replies Latest reply: May 1, 2011 10:28 AM by silverhead RSS
ckonefke Just Startin' 2 posts since
Jun 24, 2007
May 1, 2011 10:16 AM
FX Feature request for Pod X3 Live...
Hello,
I've been using the X3 Live for a while and it does a good job for most situations.  I like the upgrade with 2.0, but there's still an effect that I need, and I believe it could do, but is not included in the current firmware.
I have a few songs that require a delayed pitch change.  Currently, I have to use a midiverb in the FX loop to get the job done, which is a pain for gigs.  It seems like the X3 has the hardware required to do by itself.  You have delays with limited modulation, and you have pitch change (harmonizer) with no delay.  Just need to combine the two into a single effect.
On the midiverb there are two.  "STEREOPITCH SHFT", and "PITCH:PITCH".  The difference is subtle, but basically, when they get an input they delay for a set time up to 250ms and then play the harmonized output (+/- octave).  Then there's a feedback setting that will then delay and harmonize again.  What you get is for each note a climing set of notes.  I need this for several songs to provide a very thick open chords, or almost fugue like flat picking.  It would be great to have that on board the X3.
Here are the settings for the Midiverb.  Perhaps, you could do something similar.
Let me know if this would be considered for a future update.
Thanks,
Cliff Konefke
ckmlist@comcast.net
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
