1040 Views 3 Replies Latest reply: May 27, 2011 11:49 AM by dividedbyzach RSS
dividedbyzach Just Startin' 5 posts since
Nov 10, 2008
May 12, 2011 4:58 PM
Volume peaking and cracking when mic plugged in to toneport
Well I finally have all my drivers and hardware up to date but now when I plug in my toneport to my imac, the line level keeps peaking and cracking.
I have a condesor mic plugged into mic 1 and sometimes (not always) when I press phantom power it keeps spiking and crackling at max volume.
Any idea what's happening? It's not due to any external sound...When I clap my hands or check the mic it doesn't peak, it seems like a ground glitch.
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Hey dividedbyzach,
      Make sure that your mic cables connections are good. Make sure the condenser is not to close to the source. Try turning down the gain a little bit and monitoring the levels within the DAW to make sure its not too loud.
      If you are sure that the cracking is not due to a signal overload or clipping, then please double check all  USB connections.Please try removing any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available.
      Make sure that the UX2 is operating at the same BitRate and Sampling Rate as your Host application or Operating System.
      To check or change the Bit Rate and Sampling rate for your UX2, Launch the Line 6 Audio-MIDI device menu located in control panel in Windows, and the system preferences in Mac OSX. In addition, try increasing the buffer size on the Line 6 Audio-MIDI device menu as well.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
