809 Views 3 Replies Latest reply: May 15, 2011 3:32 AM by amx05462 RSS
lurch101 Just Startin' 2 posts since
Jun 21, 2007
May 14, 2011 4:28 AM
A string out?
I recently purchased a Variax 700 (used) which worked perfectly for a few months, but recently the A string has been significantly quieter than all the others.  Could this be a cable problem (I'm using an old network cable I had around from my POD/Floorboard setup), or is it more likely something internal?  I can record an example if need be.  Thanks for the help.
  • amx05462 Power User 3,495 posts since
    Sep 1, 2008
    May 14, 2011 4:39 AM (in response to lurch101)
    Re: A string out?
    most likely  its a  pickup  on its  way  out.    try spraying   around  the  pickup with contact  cleaner.     they  ground to the  saddle     through  the   metal case  and    if it gets  dirty    it doesnt ground  right  if that doesnt  cure  it then    most  likely   you will have to replace  it.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
