1623 Views 7 Replies Latest reply: May 23, 2011 9:24 AM by Kneehow RSS
SpawnSC Just Startin' 3 posts since
Jan 12, 2010
May 16, 2011 4:39 PM
Hooking up the POD HD 500 to Spider III 75 watt amp?
I was wondering if its possible to hook up the HD 500 up to my Spider III amp so that the sound comes out from the HD to the Spider III's speaker? if so how can I do this?
  • gregr Iknowathingortwo 639 posts since
    Oct 26, 2009
    May 17, 2011 10:05 AM (in response to SpawnSC)
    Re: Hooking up the POD HD 500 to Spider III 75 watt amp?
    I'd try running it into the CD/MP3 jack first (using the proper adapter) with the HD500 configured in either Combo Power Amp mode or possibly Studio/Direct mode, but that's me.
    Your other option is to use Combo Front mode and go into the Input jack with the amp set to Clean Red with all the tone knobs at 12 o'clock and the drive knob somewhere below 12 o'clock and work from there, tweaking until you get something you like.
    Mar 26, 2007
    May 16, 2011 5:03 PM (in response to SpawnSC)
    I don't know if this trick works on the Spider III as I haven't tried it, but for the Spider IV and Spider Valve MkII if you hold down the Tap button as you power on it puts the amp in test mode which bypasses all the DSP stuff and you can then feed the HD500 output into the front of the amp and treat it as you would a power amp.  I had reasonable success setting the HD500 output mode to Combo Pwr Amp as I recall with the Spider IV 150.  if that trick doesn't work, you can make up a special cable or use a 1/4" to 1/8" jack plug adapter and you can use the CD/MP3 Input (but the Spider III will still need a dummy jack plug into the normal front input to activate the CD input).
    Nick
        Oct 26, 2009
        May 17, 2011 10:10 AM (in response to SpawnSC)
        L and R?  I don't know how you're going about sending both of these into what I assume is a mono input.  Regardless, don't do that!  Use only one of the 1/4" outs and connect it to the input of your amp with a regular instrument (guitar) cable.
        Also, make sure 1/4" OUT switch is set to "AMP" and to turn the master volume all the way down first.  Combo or Stack Power Amp is how you want the mode set (if there is any difference between the two, I would love to know what).
  • Bluestone Iknowathingortwo 1,194 posts since
    Feb 11, 2007
    May 16, 2011 5:14 PM (in response to SpawnSC)
    HI
    I've used the HD 500 with a couple of my Spider 3's....
    I use the "old school" method of setting my amp up as clean...no FX..no verbs...EQ's set flat.....
    Let the HD take complete control.....for all the parameters......and
    Turn it up!
    OM
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Glad to hear that you were able to figure it out.
    I doubt anyone would've guessed that you had the USB connection to the HD500, but now that it's been mentioned, the "noise" issue makes sense.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
