2772 Views 12 Replies Latest reply: Jan 19, 2012 9:52 AM by jimsreynolds RSS
MagusB Just Startin' 4 posts since
Apr 9, 2011
May 16, 2011 7:40 PM
POD HD500 Tuner Accuracy
Hello guys, this is my first post here. I've been a lurker for quite some time since I have previously owned Line 6's Distortion Modeler, then Floor POD, the Floor POD Plus and finally managed to snag a decent priced used POD HD500 ($300 @ Guitar Center) and after watching countless videos, reading tons of reviews, searching these forums and reading all the pdf's about said unit that are on this site I would like to ask any of the senior members of this forums the following question: is there any info available over the HD500's chromatic tuners accuracy?
The only information I could find was one review site that claimed it was "accurate" but that is no good in the current market. If you have a $10 korg you can get within +/- 3 or 4 cents which in itself is very, very bad when considering how out of tune the whole guitar can be (given the intonation limitations of the modern guitar)
I am almost finished with my fairly "simple" pedalboard: pedaltrain pro + HD500 + E-H Knockout EQ + Boss AC-3, my Vox's footswitch and BBE Sonic Stomp...but there is room for a quality tuner and I am heavily inclined over a Turbo Tuner, Polytune or even a TU-3.
Any info regarding this would be realy appreciated.
Cheers!
  • mdme_sadie Just Startin' 113 posts since
    Sep 18, 2009
    May 16, 2011 7:47 PM (in response to MagusB)
    Re: POD HD500 Tuner Accuracy
    It's accurate to within a tolerance that you can just about get using a guitar.  Guitars really are never that accurate (and god please no-one mention the abhorance that is the new antares guitar autotune) and due to the way they're constructed, the friction, slippage etc then it's pretty hard ot tune more precisely than the tuner will work on a Pod.  As you have one I suggest you try it yourself and also make use of your own ears to determine how in tune it is.
    Having said all this I personally use Polytune for iPhone/iPad just because of the convenience factor being able to tune all the strings at once (once you use such a system it's pretty hard to go back to a normal tuner).
  • gtrman100 Iknowathingortwo 479 posts since
    Jan 24, 2007
    May 16, 2011 7:55 PM (in response to MagusB)
    All digital tuners are clocked to a quartz occillator which have accuracy beyond anyones ability to determine pitch. The HD's are the same. Much more important would be your ability to turn the tuning peg in micro adjustments. I wouldn't worry about it. Plus you can adjust the pitch reference to a different frequency if A-440 doesn't work for you.
      Sep 18, 2009
      May 16, 2011 8:56 PM (in response to MagusB)
      Surely you didn't buy the HD500 to be a tuner? o_O
      Polytune is ok in needle mode, neither better nor wore than anything else out there.
      Fact is with any tuner once you've done tuning you should go over the strings yourself playing them side by side and bring them into harmonic phase (just out of perfect phase) with each other.  However if you're unable to hear the difference between the results of the various tuners then I don't see why you should worry about their accuracy, a more expensive tuner really wont give you a better result.
      The guitar is a natural instrument.  If you want perfect pitch then it's just not the instrument for you (maybe a synth as they use even temprement).  No natural instrument is perfectly in tune, even grand pianos are actually tuned to be out of perfect tune towards the treble and bass, simply because that actually sounds better.
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    May 16, 2011 9:14 PM (in response to MagusB)
    If you really need a tuner with more precision than the HD is capable of then you will not need to ask any of us. I would save the slot for a mod, screamer or something...I get it...I intonate with a Peterson strobe...but Line 6 tuners have always worked fine for me for rehearsals, shows etc...I think HD is an improvement over XT...Easy to see...display is more responsive...Not a strobe, but darn good I think...
  • tim1953 Just Startin' 112 posts since
    Mar 20, 2011
    May 17, 2011 8:51 PM (in response to MagusB)
    The HD 500's tuner is okay for a quick reference but it is not as accurate as my Conn Strobe Tuner or even my Peterson Strobe Clip digital tuner.
    I'm one of those guys that has never really liked any of the cheaper digital tuners and I certainly won't trust them setting up the intonation on my guitars.
    That's why I've been using the trusty (and crusty) old Conn Strobe tuner which in my opinion is still the most accurate tuner I've ever used.
    The little Peterson Clip does a pretty nice job and is my second favorite but I still prefer the Conn.
    I hope this helps and as always this is my opinion and not meant to create a backlash of arguing....
  • grimm26 Just Startin' 303 posts since
    Nov 13, 2007
    Jan 19, 2012 8:58 AM (in response to MagusB)
    I'm tempted to get the TC polytune not only for the accuracy and ability to tune all strings at once, but also because sometimes I play with just guiat + amp or just have the HD500 in the loop.  Plus, I can power a wah and wireless unit through the polytune and only take up one plug spot.
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Jan 19, 2012 9:20 AM (in response to MagusB)
    I would love to play in a band where I have enough time between live songs to care whether or not all my strings are within 1% of true !  98.275% of the audience won't appreciate the benefits you bestow on them.
    I let the guitars warm up to the room temperature and give the guitars a close tune when I start including a little of Sadie's 'harmonic' tuning if it 'feels wrong'.  Thereafter I will tune it maybe once or twice during the set and that will be quick and dirty.  The HD built-in tuner is good enough for me in a gig situation.
    For recording or intonating a guitar I would be more concerned and might  but for live: speed of tuning is much more important to me than getting into some tight loop about whether I am completely below the limits of human perception.
      Jun 27, 43450
      Jan 19, 2012 9:52 AM (in response to jimsreynolds)
      And now that Mr Ranty has left the house ... I do like the idea of the polytune, less for its accuracy but more for the idea that you can just give the guitar a quick strum and see immediately how far out the tuning is.  I don't know if it is that good in practical use but it catches my fancy for sure,
      Incidentally, one of the best tuners I own is a tiny little Planet Waves strobe tuner.  Size (and shape) of a pic and uses two strobing LEDs to measure frequency - you hold it over the 12th fret and the string strobes faster when further out of tune.  Works brilliantly and is really accurate (to my ears).  Works in a loud environment and on a dark stage.  Works on acoustics just as well.  Only major drawback is that it is useless in direct sunlight, outside.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
