May 17, 2011 2:26 PM
PodFarm 2.5 Vst Currupt Graphics
Like (0)
Since installing Podfarm 2.5 the graphics on my podfarm vst have all gone strange (see attached pictures)
I have tried re-downloading and reinstalling pod farm a few times to no avail
I am using ablton Live 8 on Windows 7 (64bit)
I will try to completely remove the plugin and reinstall again any suggestions are welcome
I have exactly the same problem using Sonar X1 Producer (fully patched). The update cannot be used looking like it does. The standalone version is ok.
Grum.
I had the same issue and was able to fix it by:
1. Download POD Farm 2.5 (fresh download)
2. Uninstall existing POD Farm 2.5
3. Reinstall POD Farm 2.5 - Create a special directory C:\Program Files (x86)\VstPlugins and install the plug in portion there
4. Make sure the directory referenced above is in your DAW's VST search path
That fixed it for me.
I'll try that. Unfortunately I've just done a system restore to try to go back to 2.02 but all that did was corrupt the standalone version as well!
I can say with some confidence that I'm not a happy bunny at this point in time.
Grum.
In general, you will see bad graphics if you move your VSTs or install them to a custom location. You are actually still instantiating the *2.0* VST plugin in your DAW – not the 2.5 plugin. In order to fix this, either:
-Copy the 2.5 VST from \Program Files\Line 6\ to the place where the 2.0x VST is
or
-Reinstall POD Farm 2.5 and tell the installer to install the VST to the same place where the 2.0x VST is.
or
-Uninstall everything and just install POD Farm 2.5
All I did was install to the default location! As it all works now I'll ignore the insinuation that it failed due to something I did ;).
Grum.
As answered below
This was just a case of me having to manually uninstall all of the old Podfarm dlls from the VstPlugins folder
