1627 Views 13 Replies Latest reply: Jun 14, 2011 5:44 PM by jdolby RSS
BMoe Just Startin' 62 posts since
Feb 7, 2010
May 17, 2011 4:59 PM
DT50 crackling noise question?
Thru the forums, I am aware of the " white noise issue. But I have that and also there is a sort of crackling
noise, more like a lightning/storm interference on an am radio noise, or a continued "dirty pot" noise?
It doesn't happen when the amp is first turned on but after a couple of minutes is appears.
This seems to be only when the A/B is selected.
My question is, could this be a faulty preamp tube, and can I change them if still under warrenty?
I know you can't use "long plated" tubes. I was thinking of the Tung_Sol 12AX7.
Just received it last week, and I love the tones on this amp and with the POD HD500, Sweet, Sweet , Sweet!!
Thanks for your answer in advance.
Regards,
BMoe
    Dec 22, 2006
    May 17, 2011 5:03 PM (in response to BMoe)
    Re: DT50 crackling noise question?
    there really isnt any pre-amp tubes... the pre-amps are modeled.
    i'm certain that changing any tubes won't hurt the warranty as long as the tubes are within spec.
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    May 17, 2011 6:57 PM (in response to BMoe)
    This is not an official recomendation but, generally you want to avoid the long plate in a combo if you like to play loud...They go micro faster...the plate is long...doh...In a head I think you have more leeway...I recently put in a Mesa SPAX7 in the buffer and a GT SAGAX7 balanced inverter...very nice improvement over the EH vibe...I swear SPAX7s are one louder... They are very quiet too...
  • SStiv Just Startin' 68 posts since
    Feb 22, 2007
    May 18, 2011 12:32 PM (in response to BMoe)
    I used Tung_Sol 12AX7's to correct my white noise problem.
  • jdolby Just Startin' 80 posts since
    Jan 24, 2007
    May 18, 2011 1:19 PM (in response to BMoe)
    BMoe,
    Your problem sounds the same as mine.  I changed the two 12AX7's in mine and the white noise got quieter did but not entirely go away.  Around that time I started to use the HD500 with the L6 link.  I do not get the crackling when using the L6 link.   It does crackle when I plug directly to the amp guitar input (high).  It's like a "dirty pot" as you say.
    If I honk on a chord it is more pronounced.  It gets loud for a split second then goes away.
    I wonder if any of the Line 6 guys could chime in here.
    When I get home from work I'm going to call Line 6 for some help and see if I can get this sucker repaired.
    • arcticman Just Startin' 114 posts since
      Feb 6, 2007
      May 18, 2011 5:33 PM (in response to jdolby)
      jdolby,
      Please let us know what you learn from L6.
      I have had the same "crackling" on my DT50 112... but it's very intermittent.
      thanks
        Jan 24, 2007
        May 26, 2011 2:22 PM (in response to arcticman)
        I've been busy with work and life in general.  Today, I finally took my DT50 Head to the point of purchase.  It will be repaired by the local Line 6 repair guy.  So your guess is as good as mine right now.  Hopefully it won't take very long and comes back silent or near enough.
        I'll keep you posted.
        JD
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Jun 2, 2011 9:15 AM (in response to BMoe)
    Re: RE: DT50 crackling noise question?
    This may be moot by now, but I just came across this thread this morning... all the info that Space, Zap and SStiv provided is correct.
    However, with any of our digital modelling amps (with or without tubes), a big portion of the amp's sonic "performance" is also driven by firmware (system software code). While ultimately, the root cause of this issue you guys are having could be hardware (tube-section) related, I need to remind you guys that you should consider a firmware re-install as one of the first steps when troubleshooting audio-related issues.
    To do this, you'll need a MIDI-to-USB hardware interface to link the amp to a host computer. We've had the best luck with M-Audio's MIDIsport UNO and other customers have chimed in that the Yamaha UX16 (similar to the UNO) work great.
    Line 6 Monkey is the free software application that enables you to "look" inside your DT50's system software via USB-to-MIDI connectivity.
    You then click on the "Flash Memory" component in the Monkey software program and click "Update Selection" or "Reinstall Latest" (whichever appears... this will vary from amp to amp, depending on the user's history with doing Flash Memory update/reinstalls).
    If you try this and are up to the most current DT50 system software and the issue STILL persists, then a trip to an authorized service center tech would be in order.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
