838 Views 3 Replies Latest reply: Jun 7, 2011 5:47 PM by Line6Hugo RSS
Deadpoet Just Startin' 4 posts since
Sep 5, 2007
May 26, 2011 5:50 AM
4 days POD X3 ground issue when plugged USB, and master vol question
Hi there! I recently purchased a Pod X3, and i have a serious ground issue, but ONLY when the volume switch on my guitars, are off (no sound). I just realised that this happens only when the usb cable is plugged. Can you help me? (i tried all the usb ins on my pc AND laptop, with 3 different usb cables, and the problem still exists...)
Also i noticed that the master volume knob, starts working after the 9 o clock indent. Is that ok?
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Hey Deadpoet,
      So you only experience the grounding problem when you adjust the volume knob on your guitar when its plugged into the USB port? Have you tried this with a different guitar to make sure it's the guitar that is causing this.
      Try and isolate each one of the components from the issues one at a time.
      -Try using without the USB.
      -Try using the the USB with no guitar attached.
      -Try a different guitar.
      -Try a different power source.
      It could be the X3, the guitar, or the computer. Try your best to figure out which one.
      If it comes down to the X3, make sure that it is being powered correctly, and if you are still having problems with the grounding, you make take it to a local Line 6 Service Center for assessment. To locate a Line 6 Service Center in your area please follow the link below:
      http://line6.com/service_centers/
  • Line6Hugo Line 6 6,580 posts since
    Apr 8, 2007
    I'm glad that the problem is resolved.
      Regards,
      Line6Hugo
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
