1696 Views 7 Replies Latest reply: Jun 12, 2011 8:45 AM by Grega86 RSS
robertray Just Startin' 2 posts since
Jun 5, 2011
Jun 5, 2011 7:41 PM
running into two amps` effects loops with m13
Is it possible, using the m13`s stereo ins/outs, to run into two seperate amps` effect loops. Ive read on the 4cm, but what Id like to do is different I believe. Basically, m13`s input 1 to efx send of amp 1, input 2 two efx send amp2, m13 output to amp 1 return, m13 output to amp 2 return. Splitting the guitars signal via aby box into the front of both amps. I guess you`d call this the 6cm. That way I use the both amps natural gain, but the m13s modulation effects would be ran into the effects loops of both amps in stereo. Is this possible? Thank you for any help or suggestions.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
