990 Views 5 Replies Latest reply: May 1, 2012 4:57 AM by lindsayward RSS
anderson110 Just Startin' 19 posts since
May 25, 2011
Jun 10, 2011 8:15 AM
Recording video on Mac over HD500's USB, no backing track audio?
I have an HD500 connected to a Macbook using USB.
I am playing to a backing track (either through garage band or youtube, typically), and can hear everything fine through the headphone out of the HD500.
But when I record a video on my Mac of me playing, using either iMovie or Photo Booth, in both cases all I hear on playback is the guitar.  No backing tracks either from youtube or garage band.
While it may be possible to record audio/video separately and then go through a production process of syncing them after the fact, that takes a lot of time and fiddling when all I want to do is just record what I'm hearing.
Why isn't that what's happening and how do I make it happen?
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Hey anderson110,
      This is happening because the applications you are using have the POD HD500 as the designated input and output device. So even though you can hear your backing tracks, these applications are only listening to input from the HD500. There is no way around that.
      Although, its seems to me that if you have your backing tracks ready for playback within garageband, that you should be able to export that song as an audio file, and then just import that into the video software and lay hd500 track over it.
      Your other option is to use a program called Soundflower, to digitally reroute the audio within your operating system from any application into another application. This might be able to help you out.
  • rarieta Just Startin' 1 posts since
    Aug 31, 2011
      I was having the same issue, but I was able to resolve this by doing the following:
    You need the following two cables:
    1. Male 1/4" Tip - 1/4" Ring to Male 3.5 mm Tip Ring Sleeve Cable  http://www.bhphotovideo.com/bnh/controller/home?O=ProductDetail&A=showItemLargeImage&Q=&sku=160640&is=REG
    2. Male 3.5 mm TRS (tip ring sleeve) to Male 3.5 mm TRS cable
    Take the Tip - Ring 'Y' cable and plug each one into the 1/4" outs on the Pod HD 500.  The other end goes into the audio in on the Mac computer
    Take the other cable and go from the MP3 input on the Pod HD 500 to the Headphone Jack on the Mac computer.
    Make sure that you have all of your patches on the Pod HD500 when you decide to record in iMovie because you must keep the Pod HD 500's USB unplugged as the other poster said it interferes with the direction of the audio.
    Give that a try.  I was able to successfully play backing tracks from youtube while recording video of my playing without any tedious syncing audio and video.  The ouput from the HD 500's 1/4" outputs where you would have the Tip Ring 'Y' cable carries the mixed audio from the guitar and the mp3 input to the input of the Computer.
    Make sure you click on the "mic" button in iMovie and select built in audio so it knows what audio to use.
    Let me know if you have any other questions.
  • lindsayward Just Startin' 156 posts since
    Mar 7, 2007
    You could also try using SoundFlower http://cycling74.com/products/soundflower
    which is a virtual audio driver for the Mac, so you send your audio to it then send its output to your preferred device, then set your recording to record from it (multiple channels are available).
    You may also need LineIn http://rogueamoeba.com/freebies/
    which allows you to route soundflower inputs to certain channels.
    Here's a description for how to record multiple channels of a Skype call using these programs. I think you could probably make this work for your situation. http://www.wikihow.com/Record-Skype-Into-Garageband-With-SoundFlower-and-LineIn
    Let us know how you go.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
