1711 Views 5 Replies Latest reply: Jun 23, 2011 1:25 PM by rizzorock RSS
rizzorock Just Startin' 32 posts since
Jan 13, 2007
Jun 14, 2011 3:13 PM
M5 delay boosting volume when run thru amp FX loop
This question has been raised a couple of times with no real responses -
http://line6.com/community/thread/38553
http://line6.com/community/thread/10165
Is there a trick to this? I absolutely love the Line 6 stuff. I am a professional musician and gig out with the Relay 90 and usually an M13 or M9. Used to use a DL4 for years.
I have an M5 in my new rack setup running thru my Bogner XTC 101B FX loop using an RJM RG16 to turn it on and off using a loop in the RG16.
Anytime loop 5 (the M5) is activated there is a quite noticeable jump in volume, almost like a solo boost. Unfortunately I'm not always soloing when I turn on my delay.
Is there any hope for a cure?
    Jan 27, 2010
    Jun 15, 2011 4:00 PM (in response to rizzorock)
    RE: M5 delay boosting volume when run thru amp FX loop
      I think I need to understand your setup a little better before providing an answer.
      Have you tried adjusting the Effects loop return master volume on the Bogner head?
      does the M5 boost happen with one delay preset or anytime you engage the M5?
      Thanks,
      David
      Line 6 Customer Support
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Jun 23, 2011 11:58 AM (in response to rizzorock)
    Hey rizzorock,
      It sounds like its the level of the effects loop on your amp, especially by the way described it. I had the same problem with my VOX effects loop, but in the end I liked the boost because I wanted my effects to be more noticeable then my regular tone, if it gets too out of line I would just roll down the guitar volume a touch. Although glad to see that you found a solution that worked for you.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
