1710 Views 3 Replies Latest reply: Jul 7, 2011 11:54 AM by Line6Don RSS
horbag Just Startin' 26 posts since
Jul 17, 2007
Jul 7, 2011 2:36 AM
use m13 with external stomp boxes in the 4 cable method via the effects loop
i want to use external stomp boxes with my m13 and was wondering what ways there are to connect them in the 4 cable method ie in the effects loop or other ways
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    External pedal effects can physically be placed anywhere in the signal flow, really. The limitation would be the number of physical patch cables you have available to use.
    You could put a pedal in between your instrument and the input to the M13. You could put some pedals between the Effect Send of the M13 and the Amp's input jack. You could put an effect in the Amp's Effect Send output into the Effects Return of the M13. And lastly, effects could go in between the Out of the M13 back to the Amp's Effect Return jack. The quality of how your effected signal sounds to you, however is going to be subjective and subject to the interaction of all these hypothetical devices on your sound. You'll definitely have to experiment to find what works best for you.
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Hey horbag,
      You will need to hold the looper controls button to access the setup menu. Within FX 3 display you will see a parameter for FX LP. You can use the right most lower knob to control at which point the in M13 signal flow the effects loops is placed. you will need to connect the stomp box to FX send from the M13 and then connect that to the input of your amp, or you could connect it from the effects send of your amp and then into the effects return on the M13.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
