1384 Views 6 Replies Latest reply: Jan 25, 2013 11:36 AM by jzlavallee RSS
jzlavallee Just Startin' 4 posts since
Nov 23, 42958
Jul 10, 2011 11:27 AM
Spider Valve MKII 112: Buzzing out of nowhere...
..so I was practicing a few days ago when all of a sudden this LOUD and very suddle buzzing came out of nowhere through my amp.  I tried to turn the master  and channel volume knobs all the way up and down and it has no effect on the volume of the buzzing.  When I turn the standby switch on, the buzzing starts to cut out but barely.  I tried playing through it again yesterday, it played flawlessly as ever for about 10-15 mins then the sudden loud buzzing came back and I had to shut it off.. but before i did, i put it on standby and waited for the buzz to stop, which it did, then I turned standby off and it was okay.. I tilted the amp forward to look at the tubes and + & - wires for the speaker to check them and the buzz came back as soon as I did.  This is my first tube amp and its not quite a year old yet.  Ive checked both fuses and they seem to be okay.. All of the pre amp and power amp tubes are lit evenly and they dont seem to have any problems with them either (that I know of).  The amp is as powerful and clear as the day I got it until the random buzz starts.. when it does, no sounds from the guitar can be heard through it at all.. it's just a straight loud buzz.  I'm about to try to play straight into the amp to see if the buzzing comes back.  Both times before, I had a POD HD300 that i was playing through as well, but i turned the volume down all the way on the pedal and it still didnt stop the buzzing.  Oh, and by the way, I don't know if this has anything to do with it but when it starts to buzz and I turn standby mode on, I can hear a light ticking sound coming from the back of the amp, almost like an analog clock.  Whatever it is, its freaking me out because it's not a cheap amp and I'm lost without its amazing sound.. I would greatly appreciate it if someone could help me out with this problem as soon as possible.
    Jan 27, 2010
    Jul 11, 2011 3:00 PM (in response to jzlavallee)
    RE: Spider Valve MKII 112: Buzzing out of nowhere...
      This could be related to the power in your room. Try the amp in different locations and see if the buzz persists.
      If the buzzing continues or grows louder it could be an issue with the tubes.
      If so, I would suggest taking the amp to an authorized service center for repair.
      http://line6.com/service_centers/
      Thanks,
      David
      Line 6 Customer Support
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Jul 13, 2011 9:13 AM (in response to jzlavallee)
    Hey jzlavallee,
      Please let us know your results once you are able to thoroughly test it using different power outlets and locations within your room.
      Thank you.
    • frenk4christ Just Startin' 1 posts since
      Apr 24, 2011
      Jan 25, 2013 2:04 AM (in response to jzlavallee)
      Re: Spider Valve MKII 112: Buzzing out of nowhere...
      I have the amp for 1 and a half years. Before I "only" had the volume problems, but now I still have the same super loud buzzing problem, and I still don't know what to do. It seems to me that I was never really able to use this amp! Did you find a solution?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
