959 Views 3 Replies Latest reply: Aug 5, 2011 9:02 PM by daddyjaxon RSS
daddyjaxon Just Startin' 11 posts since
Feb 7, 43373
Aug 4, 2011 6:23 PM
Using POD HD with Peavey ReValver?
Whatup fellas:
I have a POD HD Desktop unit. This device pretty much exceeds all of my expectations and I highly recommend it to everyone! However I desperately want an amp model of the Peavey 6505+ which is not yet available for the POD HD. And since I am the most impatient person in the world, I just bought Peavey's ReValver MKiii software vst plug-in. What I would like to know is: Is it possible to use the Cab Models and/or the effects from my POD HD with the Amp head models from ReValver? I record using FL STUDIO 10 and I use an M-AUDIO interface. If someone could please let me know if this is possible and if so please explain how to make this work. Any answers or feedback would be greatly appreciated! Thanks in advance.   Jalon
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    Aug 5, 2011 7:21 AM (in response to daddyjaxon)
    Re: Using POD HD with Peavey ReValver?
    i don't believe you can run a cab sim in the pod without an amp.  they're together in 1 block.  there's a no cab option, but not a no amp option to then run a cab with.
    that said, it would be a painful routing job to do that as there's no way to get audio back into the pod using USB.  so you'd have to run your guitar into another interface, for revalver then out then into the pod and through the POD.
    if I'm honest the bettwe way to do it would be to use IRs, although I understand if you prefer the L6 cab models as I find they sound more real than IRs alone.
  • tighttritenight Just Startin' 97 posts since
    Oct 13, 2010
    Aug 5, 2011 7:58 PM (in response to daddyjaxon)
    There are so many good free vst programs out there that I wouldn't bother with the routing for just using the HD500 as an effects or impulse loader.  The main benefit of the Pod is going to be the amp modelling which frees up your cpu.  The IR's in Revalver are actually pretty good, and it gives you the option to load 3rd party IR's.  You can find them free online.
