1008 Views 4 Replies Latest reply: Dec 21, 2012 9:40 AM by metalmannathan RSS
McLisak Just Startin' 2 posts since
Aug 13, 2011
Aug 16, 2011 8:25 AM
Bad sound quality POD Studio GX and POD Farm
Hi !
I have a huge problem. I bought POD Studio GX 2 days ago and spent a long time searching a solution. I mean is sound quality is very bad. It sounds horrible with POD Farm stand alone, as well as a VST plug-in. I never found anyone who had problem like this.
Here is an mp3 i recorded with POD Farm 2.51 as VST in REAPER.
http://www.mediafire.com/?umem0feswv46g4v
That record should tell everything. Please help me as fast as You can becouse i want to record my tracks as fast as possible Waiting for answer.
Greetings,
McLisak.
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Aug 19, 2011 1:02 PM (in response to McLisak)
    Re: RE: Bad sound quality POD Studio GX and POD Farm
    Hey McLisak,
      Thank you for providing a sound sample of the problem you have been having.
      After listening to the sound clip, I did not notice anything in particular that sounded like a technical problem. It sounds as though maybe you are just not satisfied with the type of distortion you are getting?
      Have you tried using different amp models or trying a different guitar?
    Mar 14, 2011
    Aug 19, 2011 1:09 PM (in response to McLisak)
    Hey McLisak,
      As I previously mentioned after listening to the sound clip you provided, there did not sound like there was any added artifacts or distortion as a result of a connection or setup issue.
      You can reference the instructions below to ensure you have your computer and GX setup properly:
      Make sure to install Line 6 Monkey as well as the drivers for your operating system before trying to connect the POD. They are both available for free download from the links below:
      Windows Drivers 4.2.4.4:
      http://line6.com/software/readeula.html?rid=3987
      MAC Drivers : 7.0.9
      http://line6.com/software/readeula.html?rid=4170
      Windows Line 6 Monkey 1.41:
      http://line6.com/getrelease?rid=4114
      MAC Line 6 Monkey 1.41:
      http://line6.com/getrelease?rid=4115
      After successfully installing Line 6 Monkey and the drivers please try removing any additional unnecessary USB and firmware devices from your computer when troubleshooting this issue. Make sure to connect it directly to a USB port and not a USB hub, extension, or keyboard of any kind, preferably connect it to a USB port on the rear of computer. Try using additional USB cables and every USB port available.
      Launch Line 6 Monkey and apply any updates that are available.
      On Windows launch the Control panel, on MAC OSX Launch the System Preferences. Select the sound options and select the ASIO GX for both your input/recording and your output/playback.
      From here, you need to launch the Line 6 AUDIO-MIDI device menu located in windows on the control panel, and in mac on the system preferences.
      Connect your guitar the proper input. Then make sure to connect headphones or speakers to the Outputs on the GX so that you may monitor playback.
  • metalmannathan Just Startin' 1 posts since
    Sep 25, 2011
    Dec 21, 2012 9:40 AM (in response to McLisak)
    Re: Bad sound quality POD Studio GX and POD Farm
    Buy the metal shop and use the Mississippi Criminal head or the Cali diamond plate head or the treadplate head and you'll get a better sound
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
