1338 Views 9 Replies Latest reply: Oct 3, 2011 5:39 PM by teqniqal RSS
DaanHoffmans Just Startin' 3 posts since
Aug 16, 2011
Aug 16, 2011 11:58 PM
chaining 10 units
Hi guys,
I am looking around for replacement of 10 wireless lavaliers for an amateur musical group. XD-V70L seems to meet our criteria, but untill now it is hard to find "real life" reviews from poeple nearby.
Is there any experience with use of this number of units for musical?
The manual states that it is not recommended to chain up the antennas of more than 6 systems. Does this also account for use with directional paddle antennas?
Best regards,
Daan
  • laplayantonio Guru 2,435 posts since
    Sep 26, 2006
    Aug 19, 2011 4:05 AM (in response to DaanHoffmans)
    RE: chaining 10 units
    hello Daan
      you may couple up to 12 units, please see page 2•3 of PDF "XD-V70 Wireless Advanced Guide (Rev A) - English" (http://line6.com/support/manuals/ )
      see also in http://line6.com/support/docs/DOC-1957 'Q: How do I connect multiple receivers for rack mounting?' and 'Q: What type of antennas work with the XD-V70 receiver (RX212)?'
      line6antonio
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Aug 22, 2011 9:51 AM (in response to DaanHoffmans)
    Re: chaining 10 units
    While it is possible to chain up 12 units you will get much more reliable performance limiting your chain to 6 units.  Since you have 10 units, I would recommend chaining them up in a 5+5 configuration.  All the parts are in the box so there is no extra cost involved.
  • DanCornett Just Startin' 93 posts since
    Feb 9, 2011
    Aug 31, 2011 8:50 AM (in response to DaanHoffmans)
    I have 12 units, and use them 'chained' in two groups of 6 -- single pair of antennas connected for each group of 6.
    One thing I did was to connect the antennas in "opposite directions" across the group.  That is: if the "A" antenna input on unit #1 is connected to the external antenna (with the terminator on "A" of unit #6), then I connect the other external antenna to the "B" input of unit #6 (with the terminator on "B" of unit #1).  This may not make a lot of difference, but (in theory) it may help a little bit to keep the "reception sensitivity" consistent across the whole group.
      Oct 13, 2008
      Sep 10, 2011 11:39 AM (in response to DaanHoffmans)
      40 cm should be fine.  You can check the signal strength on the LCD display.  Experiment a little and look for max bar length.  Then with the transmitters turned on walk around and give it a try
    Feb 9, 2011
    Sep 15, 2011 8:42 AM (in response to DaanHoffmans)
    re: antennas
    One other tip.  Get the antennas as high as you reasonably can -- so they are above people's heads, if possible.  An additional nicety would be to angle them slightly downward, if feasible (i.e. so they point toward the  opposite corner of the stage floor).
      Oct 13, 2008
      Sep 15, 2011 10:20 AM (in response to DanCornett)
      Let me clarify that a bit.  The range of about 6 - 10 feet is ideal.  As you start going higher you begin to indroduce other potential issues.  So 20 feet in the air is probably not a good thing in most cases (if they are level).
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
