1224 Views 5 Replies Latest reply: Aug 26, 2011 10:21 AM by TTMMNWmike RSS
TTMMNWmike Just Startin' 4 posts since
Jul 31, 2011
Aug 24, 2011 4:01 AM
POD X3 Crashes Reaper at random time
Hello everyone!
I purchased a POD X3 almost 3 moths ago and right from the start everytime I start recording something with the REAPER recording program,suddenly it stops recording and both the program and my computer crash.Also,the Greabox says that it doesn't detect any POD device and broughts up errors.I tried uninstalling Gearbox and Line 6 Monkey and the drivers and reinstall them but nothing have worked,same goes for REAPER.I also tried using other USB ports and the problem is still here.I doubt that it is my computers fault because it is brand new and it hadn't showed me any sign of malfunctioning.
  What should I do????!!!!it is extremely irritating recording for 2 hours or 30 minutes(and less sometimes)and then everything getting lost!!!
Best regards,
Mike C
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Aug 24, 2011 6:36 AM (in response to TTMMNWmike)
    Re: POD X3 Crashes Reaper at random time
    Is your X3 firmware is up to date? What OS are you running on your computer?
    Here are some docs that may help:
    http://line6.com/support/docs/DOC-4698
    http://line6.com/support/docs/DOC-1814
    http://line6.com/support/docs/DOC-4282
    .....it is extremely irritating recording for 2 hours or 30 minutes(and less sometimes)and then everything getting lost!!!
    As a general rule (with ANY computer file - not only audio recording) you should manually save the file periodically to avoid the loss of large amounts of data in the event of a crash or malfunction.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Aug 26, 2011 9:43 AM (in response to TTMMNWmike)
    Re: RE: POD X3 Crashes Reaper at random time
    After reading through all that you've already tried on your end, it appears that the issue is being caused by something internal to the POD X3 itself, correlated to the USB-related components.
    My guess is that the unit powers up fine on it's own and processes incoming audio just fine for hours and hours.
    In a case like this, we'll need the assistance of an actual Service Technician to open up your device and diagnose the USB components of the unit. Since USB functionality is independent of the DSP for it to work as a standalone audio processing device, this is something that someone who might've had the unit and never connected it to a computer for audio output via USB to a software recording program may not have discovered before.
    The contact for Service information in Greece is:
      Philippos Nakas Music House
      19th Km Leoforos Lavriou
      190-02 Peania-Attiki
      Greece
      Phone: +30 210 6686206/6686000
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
