Home >
Community >
Support >
POD Community Support >
POD HD >
Discussions
Latest reply:
Aug 31, 2011 9:26 AM by
Kneehow
There is a reverse delay. Or you can maybe use the quick looper and play a loop in reverse, however you cannot store the quick loop permanently.
Nick
- Report Abuse
Like (0)
Nick is correct...
In the Delay models, try using the "Reverse". Set the TIME to a "note value" for Tap Tempo control of the repeat rate. Setting the FDBCK parameter to 0% will give you a single-pass reverse repeat of what you play. MODSP to 0% and DEPTH to 0% (unless you want some modulation to your sound) and set the MIX to 100%.
This should approximate your Boomerang's reverse sound (I used to have one; I remember that effect).
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Legend
- Correct Answers - 5 points
- Helpful Answers - 3 points
About
Follow
Subscribe
