Sep 2, 2011 7:11 AM
XD-V70L Mic -- Better Pop Screen Available?
Like (0)
Our company is using two of the XD-V70L systems to deliver PowerPoint presentations. We have two speakers, each equipped with one of the systems. One of the speakers is a very animated, excited talker, and we're finding that the small pop filter for his mic is not filtering out his excitement very well. We were previously using a Shure analog system and didn't have this problem with that system (using the WL185 mics and their stock pop screens). Other than this problem, we're very happy with the XD-V70L systems but would like to know if there is a better pop screen to use with these. If Line 6 doesn't have one, any recommendations for another brand/model of screen that would be appropriate for these mics?
Even the thickest pop screens can't stop every plosive. Your best bet is to EQ at the board.
Usually a low pass filter around 80 to 120HZ should stop or drastically reduce the plosive noise.
Thanks,
David
Line 6 Customer Support
Thanks for the quick reply.
Unfortunately, our board is a rather basic one -- Allen & Heath ZED10 -- which has only three-band EQ. It does have a high pass filter button on each channel (which I assume is what you meant by "low pass filter" -- high pass = low cut). I had that HPF engaged, and I also had the low-frequency knob turned all the way down for the presentations. For all I know, maybe that did eliminate a lot of them. But enough are getting through to be distracting.
I know that the Shure WL185 mic came with a slightly bigger screen, and we didn't have any problems with that one. Which is why I was hoping that a slightly larger screen on these mics would do the trick. Or is the mic itself (regardless of screen) more susecptible than the WL185?
Wind Tech make a large varity of windscreens. It's usually just a trade off of size vs visual.
http://www.wind-tech.net/uploads/2010_WS_Catalog.pdf
The mic is not particularly different that the Shure wrt popping. You could also try adjusting your mic placement.
