846 Views 5 Replies Latest reply: Sep 13, 2011 10:41 AM by Line6Don RSS
SeattlePowerpop Just Startin' 3 posts since
Aug 3, 2007
Sep 4, 2011 10:01 AM
Model pack recognition problems.  Help!
Hi all,
This is my first post, and I"m hoping I'm putting it in the right place.  I've had great use of my Lines 6 Pod 1 and 2 for recording in my DAW (Reaper).  However, I just bought the Power Pack model, and it's not being recognized in the DAW.  Unfortunately, I can't say it's a problem with the model pack, per se, because simultaneously to that purchase, I also updated a ton of my Lines 6 stuff (Pod 2.5, License Manager, Midi Driver, etc.).  So, while everything except the model pack seems normal, for all I know it might be a problem with one of those other updates, as well.
I've dug through my settings and folders and can't figure out the issue.  When I first launched Reaper, I could see the Power Pack stuff, but I was being told that Pod 2 wasn't licensed.  I re-downloaded Pod 2.5, and that message went away, but now none of the Power Pack stuff is appearing.
I've been struggling with this for a week and would love any advice.  I'm on a Mac.  My device is a Toneport GX, and it's attached and everything else seems to be running normally.  It's just this new model pack that doesn't seem to be recognized!!  Help!
  • Line6Don Line 6 Support 5,275 posts since
    Mar 14, 2011
    Sep 7, 2011 1:48 PM (in response to SeattlePowerpop)
    RE: Model pack recognition problems.  Help!
    Hey SeattlePowerpop,
      Connect your Line 6 devices directly to your computers USB port. Close all open applications including POD Farm, launch the License Manager software to de-authorize and re-authorize your computer and devices. Make sure to remove the information when prompted to, and then install again when prompted to, this will ensure that you reinstall all of your available Line 6 assets from your account into your devices and computer.
        Jan 27, 2010
        This is likely related to a permissions issue in OSX.
        Click on Finder or the Macintosh HD icon on your desktop.
        Next go to:
        Username>Library>Application Support>Line 6
        Is the folder Empty?
        If so, control click inside the folder and select Get Info.
        Make sure that sharing and permissions for the folder is set to read and write.
        Next create a folder inside the Line6 folder called Guitarport.
        Run Line 6 License Manager, deauthorize and reauthorize the computer and Line 6 device one more time.
        POD Farm should authorize.
        Thanks,
        David
        Line 6 Customer Support
    Mar 14, 2011
    Sep 13, 2011 10:41 AM (in response to SeattlePowerpop)
      If it did not give you the option to remove and install the first time you went through the process, then I suggest you de-authorize and re-authorize your computer and TonePort GX one more time. Proceed to remove your information and reinstall the information for both your computer and TonePort GX. Make sure that you do not have any applications open when you are using the License Manager.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
