362 Views 2 Replies Latest reply: Sep 8, 2011 2:38 AM by bluepete222 RSS
bluepete222 Just Startin' 50 posts since
Jan 30, 2010
Sep 7, 2011 5:53 AM
dt 50 2x12 motorboating!
i have a dt50 2x12 which is fantastic. i changed to buffer and phase inverter 12ax7 valves to make it a bit less hissy.
i have noticed a tendency for slight oscillation on voice 4 if the preamp is on full. this results in a very low but noticeable oscillating hum due i think
to the fact that voice 4 cuts negative feedback in low frequencies. also connected to my hd500 with the divide by 13 patches the same thing is there
due i think to no negative feedback in voice 3. amp techs will tell u that having no negative feedback can cause amps to 'run away' with themselves resulting in
a 'motorboat' sound in the background. this is not a mega issue as loud its not a prob but is an issue? is it a design limitation?
note if i use the jcm800 patch into voice 2 up load with plenty of gain there is no noise which fits the parameters of voice 2 which has more negative feedback
achieving that tight marshall sound!
    Mar 26, 2007
    Sep 7, 2011 2:28 PM (in response to bluepete222)
    Re: dt 50 2x12 motorboating!
    What brand tubes did you use?  Could one of these tubes be faulty?
