Sep 23, 2011 8:03 PM
No compatible Line 6 device
Like (0)
On a clean OS X. Gearbox had a similar problem but it reported "could not create a thread". I was said as a response that Gearbox is obsolete. So I'm using PodFarm 1.2 on Tone Port GX.
On a clean system (after a reboot) I always have to start PodFarm twice to get it to recognise the device. I don't think I had this problem on Windows.
I don't like the idea that there has to be an OS state change for PodFarm (or Gearbox) to run.
I've seen lots of similar reports for OS X but no answers (except stuff like "don't use Gearbox").
I created a support ticket for you so we can resolve this issue. Please respond to the ticket. Thanks.
Q: What is a support ticket?
A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host.
http://line6.com/account/tickets/view/
Line6 support
Thanks. Have sent details. For the info of others, Gearbox sees device first time. Also, after a reboot and running Gearbox, PodFarm sees device straight away.
Well that was a huge waste of time.
Dialog, via the support ticket, has been going on since my original post.
I've done everything that was asked (removals, reinstalls etc) in each ticket response.
Now I see the entire ticket (http://line6.com/account/tickets/edit/162255) has been deleted.
The problem, of course, still exists.
Hi Hugo,
we discussed this matter last meeting:
Toneport GX is only recognised by POD Farm 1.12 at the second boot.
Can you please advise on a possible solution?
thanks
Serge
Mark,
Do you have any other USB devices connected to this computer. Completely remove ANY USB hubs, even if not in use, and test the GX on all of the computer's USB ports.
If the problem persists, I suggest testing on a different system to see if there might be a problem with the hardware.
Regards,
Line6Hugo
