1104 Views 8 Replies Latest reply: Sep 27, 2011 6:05 AM by Ax3M4n RSS
sean106ESP Just Startin' 90 posts since
Aug 29, 2011
Sep 24, 2011 10:26 PM
Moving the amp block in a patch chain?
Hi all. I notice or not sure if it is possible to move the particular amp model head/cab sim further back or forward in the chain? I tried using the move function and it just turns it into making it dual amps, or moves the mixer in front or back. Is there a way to move it more in back of the chain so I can put more FX pedals in the front or even move it more forward if I want more FX in back of the amp sim? Thanks.
  • gregr Iknowathingortwo 639 posts since
    Oct 26, 2009
    Sep 24, 2011 10:27 PM (in response to sean106ESP)
    Re: Moving the amp block in a patch chain?
    Simply move the other blocks either before or after the amp block.
      • phil_m Expert Line 6 User 4,243 posts since
        Jan 25, 2007
        Sep 25, 2011 7:34 AM (in response to sean106ESP)
        In HD500 Edit, you can simply drag and drop effects models in front of the amp model - as many you want. Also, you can drag and drop the amp block anywhere you want it in the chain. You can actually put it after the mixer block if you want to. The only thing you can't move directly is the mixer block. It moves based on the stuff around it.
        Oct 26, 2009
        Sep 25, 2011 11:16 AM (in response to sean106ESP)
        sean106ESP wrote:
        It only allows me to fill the 4 empty blocks before the amp.....and 4 empty blocks after.
        Nah, I can put any of the eight blocks anywhere I want relative to the position of the amp (or amps).
          • Ax3M4n Just Startin' 127 posts since
            Aug 22, 2011
            Sep 27, 2011 6:05 AM (in response to sean106ESP)
            Another thing you can do is MOVE the empty FX blocks (the dots or nodes). Helpful if you don't have access to HD Edit.
            I find it easier to do this than to move the Amp block which, as you describe, has a habit of best guessing where it thinks you want it.
            It's most/only useful when you want two parallel paths, with a number of pre- and post- FX in each path. You found (as I did) that the POD HD is reluctant to let you add more FX to the parallel paths over what was already there. It will let you do it, but the normally intuitive control goes out the window.
            Example:-
            I have a patch with A and B paths.  Currently it looks like this:-
            Guitar - Comp - Empty Node - Empty Node - Empty Node - A/B Splitter -
            A Path - DDelay - Amp1 - Mixer
            B Path - DDelay - Amp2 - Mixer
            Post Mix - Empty Node - Empty Node - Looper - Output.
            I would like to add an OD to Path A
            I would like to add a Filter to Path B
            If I create either of these effects outside the paths (either pre or post mono path) and then try to move them into the A or B path, what actually happens is they displace whatever is already there  i.e. one of the DD's will end up in the mono path. Equally if you move the Amp it will displace the DD then end up in the A/B split (removing second amp) or if you move in the post direction  it will go straight to post mix mono (removing second amp).
            I know it can be done because I can see other patches.
            I found that moving empty blocks does not displace FX in the parallel path. So now I move an empty block into parallel path, then just edit that block in its new position.
Bookmarked By (1)
