2163 Views 24 Replies Latest reply: Nov 11, 2011 5:40 AM by vjclaus RSS
fredo_ Just Startin' 13 posts since
Nov 24, 2010
Sep 27, 2011 10:37 AM
Big hiss / noise on mag pickups when powered via VDI
Hi everybody,
I have a quite disturbing issue on my brand new JTV 69 (Korean) and also brand new POD HD 500.
As soon as my Variax is powered by the POD through the VDI cable, the mag pickups become very noisy with a big hiss on the signal (modeled sounds are OK).
When powered by the battery, the mag pickups are perfectly clean.
The noise appears as soon as I plug the VDI cable into the Variax, even when using the guitar input on the POD and a standard jack cable.
For example, with both VDI and standard jack links between the JTV and the POD, I have noise on both "Guitar" and "Variax Ch 2" inputs (POD input configuration) ; and as soon as I disconnect the VDI cable from the Variax, "Guitar" input becomes clean.
This is not a ground loop noise, but a much higher pitched hiss.
Is something wrong with my JTV and/or my Pod ?
Thank you for your help !
Best regards,
Fredo.
  • Line6bakker Iknowathingortwo 468 posts since
    Jan 25, 2007
    Sep 27, 2011 1:17 PM (in response to fredo_)
    RE: Big hiss / noise on mag pickups when powered via VDI
        I created a support ticket for you so we can resolve this issue. Please respond to the ticket. Thanks.
        Q: What is a support ticket?
        A: A support ticket allows you to directly correspond with a Line 6 Support Representative. An email will be sent to you from Line 6 containing a link if a Line 6 support representative determines that a ticket is necessary to troubleshoot your issue. Please follow the link in the email to view your open ticket to work one on one with Line 6 Support.
        Please note: Sometimes support tickets will be filtered to spam and junk folders. If you did not receive an email from us indicating that a ticket has been created, please make sure to check those folders in your email host.
        http://line6.com/account/tickets/view/
      Line6 support
  • jayson2 Just Startin' 77 posts since
    Jan 31, 2007
    Sep 27, 2011 8:24 PM (in response to fredo_)
    Re: Big hiss / noise on mag pickups when powered via VDI
    Hi Fredo,
    Do you have your HD500 hooked up to your PC via USB as well?  If so, try unplugging the cable and seeing if you still get the hiss.  Hope this helps.
    Cheers,
    jayson
    • edstar1960 Iknowathingortwo 712 posts since
      May 25, 2010
      Sep 28, 2011 1:58 AM (in response to jayson2)
      Interestingly enough I have (EDIT) a very similar (END EDIT) problem with my JTV59-TSB, but it is most noticable when I use it with the VDI connected to the HD500 and monitor on headphones without the HD500 being connected to anything else.
      If I connect my HD500 up to my PC with the USB, and have the JTV59 connected via VDI, then the noise from the mags pretty much goes away.
      I was wondering whether in my situation it is down to a bad earth or grounding within my JTV59, because when I am connected to another piece of equipment that does have a good earth connection then the problem is very much reduced.
      This does seem to be the opposite situation from what other people have reported - typically connecting the HD500 to a PC or an amp can cause a ground loop which can lead to noise issues on the mags of the JTV.  However, in my case, I don't have a ground loop, but I do get noise on the mags when using it with VDI, with HD500 stand alone, but if I then connect via XLR to an amp or mixer, or via USB to a PC, then the noise is no longer as significant.  However, I do still get a pulsing type signal "sshhh ssshh ssshhh" and a quiet mains hum coming through when using the mags with the patches - the patch selected either diminshes this effect or makes it more prominent. These noises are lost when I start to play - but are apparent when I am not playing, particularly when at moderate to loud volume levels.
      Cheers
      Eddie
        May 25, 2010
        PS: Just to confirm, that if I use the battery power on my JTV59 and 1/4" jack connection, that I don't get the pulse "sshh sshhh ssshhh" sound on the mags and they seem just as quiet as the model Lester sound when using my X3L to record via USB.
        Cheers
        Eddie
          May 25, 2010
          PPS. Sample audio file attached so you can hear what I mean.
          There are 4 samples recorded using the same X3L patch via USB into Guitar Tracks Pro as follows:
          1) JTV on battery power - 1/4" jack into X3L - mags
          2) JTV on battery power - 1/4" jack into X3L - Lester Bridge Model
          3) JTV with VDI into X3L - mags
          4) JTV with VDI into X3L - Lester Bridge Model
          You can clearly hear the pulse sound on sample 3.
              May 25, 2010
              Sep 28, 2011 8:15 AM (in response to fredo_)
              Hi Fredo,
              Yes I have the noise gate on that patch - in fact it's a two channel patch with hi-gain amps on both channels and noise gate on both channels - which may explain why it is so prominent.
              This is my 2nd JTV - it was a replacement for one that had the switch problem - however, my first JTV59 did NOT have this problem. I also know someone else who has a JTV59 and a JTV89, and neither of those have this problem - and he has tried to reproduce it.
              So, I don't think it affects every JTV, certainly not the earlier ones, but maybe it is something that is affecting a certain batch of JTVs.
              What is the prefix of your JTV serial number?
              My first JTV59 was W1101 and that did not have the issue.
              My second JTV59 is W1104 and that does have this issue.
              Cheers
              Eddie
        May 25, 2010
        Sep 28, 2011 8:01 AM (in response to fredo_)
        Hi Fredo,
        I get a very similar sound on my mags on my JTV59, if I connect using VDI to my HD500 standalone, listen on headphones and have master volume turned to max, on a new patch that does not have any fx or amps switched on, in other words just the guitar signal straight through.
        I don't think it's normal. I think it is a fault, both on my guitar and on your JTV69.
        Cheers
        Eddie
            May 25, 2010
            Sep 28, 2011 8:40 AM (in response to fredo_)
            I am running v1.71 on my current JTV59, but I also upgraded the previous JTV59 to v1.71 just before I sent it back for the replacement and it definitely did not have this problem. So I don't think it's the firmware. I suspect that it is a manufacturing process change, either in how they assemble the guitars or a component change on the main board. However, this suspicion can easily be disproved if someone with an earlier model JTV has also experienced this problem. From what I have seen on the forums, the noise issue has only been reported for W1104 and W1107 models so far.
            I regret asking for a replacement now, as my first JTV59 only had the switch issue but it had gone off for repair and come back with the same issue, so I should have tried getting it repaired one more time  - and besides the switch issue is much easier to live with than the "noise" issues.
            Anyway this 2nd JTV will either have to be repaired or replaced now.
            Eddie
            May 25, 2010
            Sep 29, 2011 4:04 AM (in response to fredo_)
            Hi Fredo,
            On my JTV59,  I also have an issue with noise on some of the factory model sounds, whether running on battery or with VDI (in fact it seems more prominent when on battery).  I get what sounds like "radio interference" type sounds for positions 2 and 4 of CHIME and ACOUSTIC (the 12 string models) and also positions 2,3,4 of CUSTOM2.
            Please find attached recording of each position (1 through 5) in factory default model banks CHIME/ACOUSTIC/RESO/CUSTOM2 of my JTV59 on battery power connected to X3L via 1/4" jack running through same clean amp patch.
            This demonstrates the weird interference noise or radio noise that is present on some of the models. You can clearly hear when the noise is present in comparison to the models that don't have it. I recorded each bank in sequence with a short gap in between, stepping through switch psitions 1 to 5, and playing each string individually at each position.
            The noise is most noticable on the CHIME and ACOUSTIC 12 string models, and on positions 2,3,4 of the CUSTOM2 bank (not as prominent in pos 3).  The RESO bank seems fine although there is a slight hint of something in pos 4 (BANJO) position but it is not significant and you have to have recording level at max to capture it.
            The recording shows factory default models for switch positions 1 through 5 in sequence for each of the following model banks:
            Section 1 - CHIME
            Section 2 - ACOUSTIC
            Section 3 - RESO
            Section 4 - CUSTOM2
            Do you have this issue with your JTV69 or are all your model sounds silent regarding background noise?
            Thanks
            Eddie
            PS: I don't have this problem with my Variax 700 and I did not have this problem with my first JTV59.
                Jan 31, 2007
                Sep 29, 2011 6:21 PM (in response to fredo_)
                Actually Fredo, that might be a good thing.
                The fact that both of you have problems with the exact same models but are playing different JTV's, could suggest that a firmware fix rather than a hardware fix might be a solution.  If that's the case, I hope L6 can figure out the problem.
                Cheers,
                jayson
                May 25, 2010
                Sep 30, 2011 2:51 AM (in response to fredo_)
                Hi Fredo,
                Yes - the JTV certainly rocks! Shame about these annoying problems - but when it's working 100% it is an awesome guitar!
                Do you also experience an earthing issue when you are running just the mags? Do you notice a slight fizz or buzz when you touch the bridge or the strings that reduces the background hiss?  Specifically when you get the noise using the VDI ? And maybe at other times too?
                If you get a moment, please can you try using your HD500 standalone with just headphones. Connect your JTV to it with the VDI. Select a new patch which ensures you will have no amps or fx's active. Then turn the Master volume up to max and listen to the ambient noise of the mags, try touching the strings and the bridge and see what effect if any that has. Then do the same for the models you listed above, Chime and Acoustic positions 2 and 4, and Custom2 positions 2,3,4.  And just for grins check out the RESO bank, because you may now hear a noise on positions 2 and 4, or at least on 4.
                I am very interested to hear what you discover, as these are all the issues I get on my JTV59.
                Thanks very much.
                Eddie
                    May 25, 2010
                    Hi Fredo,
                    Thanks for doing the tests and recording your results.
                    It is interesting that you say the slight fizz when touching the bridge is the same as you would get from any other guitar - I only get this on my JTV59 and my Gibson LP Standard, I don't have any fizz problem on my Fender Telecaster Custom FMT HH - it is silent. Ideally you should not get any fizz if the guitar is earthed correctly and I did not have that issue on my first JTV59.
                    This second JTV59 has already been with Line6-UK for a couple of weeks to get these items plus the switch problem repaired - unfortunately it came back with only the switch issue repaired but Line6-UK did not experience the other problems on their tests which is why it was sent back to me. So either something has worked its way loose during shipment back to me, or has subsequently failed, or the problems were not highlighted in their tests.
                    They have now suggested another replacement guitar - so I am waiting to hear back from them on when that will be available - hopefully soon - and hopefully it won't have any of these issues.
                    Good luck with getting your issues resolved - they do sound almost identical to mine.
                    The Line6-UK team will take good care of you.
                    Best Regards
                    Eddie
  • lindsayward Just Startin' 156 posts since
    Mar 7, 2007
    Those positions (chime/acoustic 2 and 4) are all 12-string models. I'm not sure about custom2, but they could be alt-tuned, are they?
      May 25, 2010
      Yes they are.
      NB: No problem like this on my first JTV59 or on my Variax 700 for same models.
      On this second JTV59 there is no problem on Custom2 positions 1 and 5 either - but 2,3,4 all suffer.
          May 25, 2010
          Oct 12, 2011 10:26 AM (in response to fredo_)
          Hi Fredo,
          Thanks for the update.
          I am surprised that your guitar has been verified as performing normally - it certainly sounds bad to me IMO.
          I have also been told that the hiss on mags via VDI is normal behaviour, however, I think that in some JTVs it is more noticable than others, hence the reason I didn't spot it at all on my first JTV59 - I wish I could get hold of my first JTV59 to try a side by side comparison just to prove that.
          I have also been told that the issue has been escalated to the US and that they are hopeful it can be fixed by software upgrade - so, as you say,  we will just have to wait and see.
          As you also pointed out - if this is common behaviour then I am surprised that more people have not complained about it on the forums.
          Best regards
          Eddie
            May 25, 2010
            Quick update to let you know that I got my replacement guitar last week and it has none of the problems that I have mentioned here and it works just as well as I remember my first one working.  It does have hiss on the mag pick ups when using the VDI but it's nowhere near as bad as the other one. And it does not have any earthing issues or any weird radio noises and the ambient noises on the 12 string models are now just background ambient noises that can easily be ignored.
            Apparently my faulty one will be sent off to the USA for further analysis so I hope they get to the bottom of it and determine if its just that guitar that is affected or whether others can also have the same problem.  Meanwhile, my new one is sounding great and not giving me any problems - so I hope it stays that way.
            Good luck with getting your issue resolved Fredo - I hope you don't have to wait too long.
              • vjclaus Just Startin' 21 posts since
                Jan 25, 2007
                Nov 11, 2011 5:40 AM (in response to fredo_)
                hi there, i have the same problem with my jtv59 CSB, big hiss on the magnetic pickups and on the models it´s noticeable. Some guys in the forum told me it´s a ground hum, cause i have connected it to the pod x3live, but with my other guitars there´s no noise hiss.
                what should i do?
                i put a soundsample in the thread ground hum noise
                vjclaus
                serial nr. 1018
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
