1145 Views 11 Replies Latest reply: Mar 4, 2013 1:56 AM by philmadewell RSS
philmadewell Just Startin' 12 posts since
Jan 13, 2010
Sep 28, 2011 5:49 AM
problems with my g90
After about 20 minutes of using my wireless, it is cutting output level. I run a tube amp that cleans up really well when you roll back the volume, so you can imagine why that might be detrimental to a guy in a metal band! the batteries are fresh, and the body pack says they are still at full charge. any ideas?
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Sep 28, 2011 8:27 AM (in response to philmadewell)
    Re: problems with my g90
    How much do you thinkk it's dropping?  10% 50% 90%???
    While Line 6 digital wireless battery condition does not affect sound quality or level.  Remember we are sending data not audio.
    It's possible that the output section has a problem, but this could also be caused by things other than Relay.  Can you try it with a different amp and guitar?
    A proper test would be to send a sine wave into the transmitter and then monitor the level over time to see if or how much it changes.  This would be relatively easy to do if you had some recording equipment.  This would give you a much better understand of what is happening.
        Oct 13, 2008
        Sep 29, 2011 9:51 AM (in response to philmadewell)
        I can't explain it.  If the level is actually dropping I would suspect some sort of hardware failoure.  There's nothing in the "digital RF" that can cause this.  Battery condition also does not cause any changes to audio level or audio quality.
        You can try the test I outlined above and see what is happening.  If you see a drop that would rule out other things in your system being the cause.
  • Line6Don Line 6 Support 5,274 posts since
    Mar 14, 2011
    Oct 4, 2011 11:09 AM (in response to philmadewell)
    RE: problems with my g90
    Hey philmadewell,
      Let us know your results once you are able to test your Relay G90 as dboomer suggested above.
        Oct 13, 2008
        Dec 10, 2011 9:18 AM (in response to philmadewell)
        Hey Phil
        We always have two potential problems when someone posts a problem like yours ... it's either a hardware problem or a local condition problem.  What I attempt to do here on the forum is to guess best I can which one it is so that people don't unnecessarly send in their gear and are left without it for the couple of weeks it takes to send it to us.
        Since you started this thread in September and it's now December it appears that the time element isn't the most important thing to you.  Why don't you just contact our service department, send it in , and have us test and or fix it and get it back to you.  We'd be happy to take care of it.
      Oct 13, 2008
      Dec 11, 2011 8:25 AM (in response to philmadewell)
      "contact us" link at bottom of page
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
