1881 Views 5 Replies Latest reply: Jan 29, 2012 11:09 AM by jimsreynolds RSS
oommen Just Startin' 1 posts since
Dec 29, 2007
Oct 3, 2011 9:48 PM
POD HD500 dsp limit
Is it possible to upgrade the POD HD500 DSP limit? I'm loving the sound and flexibility I get from my HD500, but the problem I've been facing is the amount of pre show work I have to put in to assigning different sounds to different presets - I've been trying to configure mine to work as a traditional pedal board with all 8 switches being assigned to different effects, but it's virtually impossible for me to do this without reaching the DSP limit. I understand that certain effects like reverbs take up more memory, but still, this is leaving me feeling very limited without the freedom of selecting effects on the fly the way you would with a traditional pedal board, instead of having to program a bunch of presets with different sounds
  • gregr Iknowathingortwo 639 posts since
    Oct 26, 2009
    Oct 3, 2011 10:35 PM (in response to oommen)
    Re: POD HD500 dsp limit
    Other than reducing the overhead through making compromises or careful effects selection, the DSP limit is what it is.  There is currently no provision for upgrading.
    One thing you didn't mention is whether moving from full-amp models to preamp models is doable.  This will free up DSP resources as well.
    Of course there isn't anything stopping you from incorporating additional effects around your HD500, either before the guitar input, in the loop or after the output as you would with a traditional pedal board.
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Oct 4, 2011 2:55 AM (in response to oommen)
    Again, if you are using a 'real' guitar amp that works for you, you can use the pre-amp/Power amp from that and just use the HD for effects.  This will free up a lot of DSP - I rarely see an issue in that mode.
    Understand why you may not want to go that way though ...
  • Finewest Just Startin' 13 posts since
    May 9, 2010
    Jan 29, 2012 10:47 AM (in response to oommen)
    I also am having the same issue... I want to use my Desktop POD HD with  my Line 6 expression board as a line in recording effect processor pedalboard, but am running into the same DSP overloads. Very fustrating. I also have a "real amp" Bugera V22 that has a effect loop so I can go direct to its amp bypassing the pre-amp, but this model amp does not have a line out for recording... I don't suppose a firmware update would help?
      Jun 27, 43450
      Jan 29, 2012 11:04 AM (in response to Finewest)
      Depending on the firmware you are coming from and to I suppose it might help but I have not heard any suggestion that there has been a big drop in DSP on any FW updates.  Nor have I seen anyone tracking the differences.
      There is an old thread on DSP usage here that may help with choosing your doom.  http://line6.com/support/thread/50339
        Jun 27, 43450
        Jan 29, 2012 11:09 AM (in response to jimsreynolds)
        You might find that you can get away with running Output 1 from the HD to your Bugera power stage and Output 2 into a DI Box that includes a speaker sim.  That DI box would go to the desk. At least one of the expert users here uses this method (Nick_Mattocks).  Make sure that your Panning is all centred if you go this way.
        I think Behringer (amongst others) has such a device.,
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
