1200 Views 3 Replies Latest reply: Oct 20, 2011 9:44 AM by Kneehow RSS
mnelson_1964 Just Startin' 2 posts since
Aug 14, 2011
Oct 11, 2011 5:30 PM
Help! Is my Spider Jam Shot?
The tap button on my Line 6 Spider Jam started flashing very fast when I powered up the amp until I either pressed it or turned down all of the effect knobs. Then I powered it up once and it went into the Line 6 Spider Jam demo and then went to a screen that just displays "Line 6." Now I have nothing except for that display. The amp won't do anything. I have tried a factory reset with no success and now I am terrified that my amp is shot. Any suggestions?
    Jan 27, 2010
    Oct 14, 2011 3:51 PM (in response to mnelson_1964)
    RE: Help! Is my Spider Jam Shot?
      Try a factory reset on the Spider Jam:
      Hold down the settings/tone button as you turn on the power and hold the button for 5-8 seconds.
      Thanks,
      David
      Line 6 Customer Support
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Oct 20, 2011 9:44 AM (in response to mnelson_1964)
    Re: RE: Help! Is my Spider Jam Shot?
    I would say before going the route of a Service Center, a reinstall of the firmware is most definitely something you can try (provided you have access to a standard SD card less than 2 GB).
    Here's the link to the Spider Jam 2.09 firmware install/update instructions document: http://line6.com/support/docs/DOC-4778
    If you have the time to give these steps a try, please do so. If after a successful reinstall of the Spider Jam's firmware you should continue experiencing this symptom/state, then the bad news is that the problem is much deeper than the system software realm and occurring on the hardware component level. In this case, only a repair technician will be able to diagnose the point of malfunction and offer a physical solution (replacement of a hardware component board, most likely). Let's keep our fingers crossed that a reinstall of the amp's system software/firmware will do the trick!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
