391 Views 1 Reply Latest reply: Oct 13, 2011 8:48 AM by dboomer RSS
bleepo Just Startin' 1 posts since
Oct 13, 2011
Oct 13, 2011 4:28 AM
XD-V30 Low output
I've been having issues with my XD-V30. When using it in rehersals, I need to put my trim up to about 80% on my mixer (Peavey 16fx). This is coming from an assortment of mics (SM58/beta 87a/om3/akg/ev) all sitting around  half. The Peavey is specified with 60db of gain, and the XD-v30, from what i've seen should be needing around 25-30db. In order to get a usable signal, I've had to add too much gain which makes the mic feedback.
Does anyone have any insight? The mixer doesn't have an input pad, eq has been set flat, and I'm connecting direct via xlr. I have also tried this with a studio preamp as well, and the situation was the same. I'm working with a loud vocalist, and she has very good mic control.
Much appreciated!
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Oct 13, 2011 8:48 AM (in response to bleepo)
    Re: XD-V30 Low output
    Yes ... 25-30 dB of gain should be about right for a vocalist.  Set your channel trim there.  Now press the solo/PFL button.  What does the meter show?  Now without touching any controls, unplug the receiver and plug in a mic in it's place.  Now what does the metering show (in PFL)?
    Do the audio LEDs (green) on the receiver seem to be bouncing normally?
    Just to be sure ... you have tried with different mic cables and you don't have anything inserted in the channel, correct?  Have you tried this on multiple channels all with the same result?  Have you tried this on a different system?  It is possible that you have a unit with hardware issues, but if it seems to work normally except for level it is not very likely the cause.
    Feedback is not a function of the channel trim exactly.  It is caused by "system" gain.  In other words you could crank the channel trim wide open ... feedback will follow the output level from the mixer.  So if you are getting feedback with the V30 but not with the wired mics it is because the V30 has more output into the system.  In fact I did some recent testing between the mics we model (sm58 model is included in the V30) and our wireless had better gain before feedback than ANY of the wired versions did.
