900 Views 2 Replies Latest reply: Oct 21, 2011 10:45 AM by Line6Tony RSS
ericckostonn Just Startin' 4 posts since
Jan 8, 2011
Oct 15, 2011 1:58 PM
Problem with my Spider Jam 4
Hello,
I have a Spider Jam 4 from 2009 and i'm having problems with the amp right now. The volume on the amp is very off. When i turn the amp model to insane the volume is loud and correct, but as i gradually turn the knob down to clean the volume decreases until it is almost impossible to hear even when the volume is all the way up. It could be a simple fix, but it is bothersome. Any help is greatly appreciated. Also as another question, I use my Acoustic Electric in the amp as well and when I play the guitar is able to get sound but when i strum too hard it clips and makes an abrupt loud noise and then goes back again. It is a Takamine G series guitar, and I have ot a clue what the issue is. Oce again any help in either of these problems is greatly appreciated.
Ben
    Jan 27, 2010
    Oct 18, 2011 10:29 AM (in response to ericckostonn)
    RE: Problem with my Spider Jam 4
      It sounds like the gain staging on your presets is off. Try adjusting the channel volume on the cleaner presets and saving them with the same relative volume as the insane setting you are using.
      If this is done correctly you should be able to "level" the volume between the presets.
      Thanks,
      David
      Line 6 Customer Support
  • Line6Tony Line 6 Support 1,917 posts since
    Jan 16, 2007
    Oct 21, 2011 10:45 AM (in response to ericckostonn)
    Hello. It has been at least 72 hours since we've heard from you. We're going to assume your question has been answered and close this thread. If you feel your question(s) have not been answered, or, if you have further questions, please feel free to re-open a support thread within our support community and we will answer your questions accordingly. Thanks!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
