3873 Views 33 Replies Latest reply: Nov 16, 2012 2:04 PM by TheRealZap RSS
piratazo1 Just Startin' 7 posts since
Oct 14, 2011
Oct 18, 2011 4:09 AM
How is it possible that the XPS-DI box is no longer manufactured?
Hi all
I apologize, my English is very basic.
I bought the guitar James Tyler and I am delighted with it.
But I'm very disappointed in is the power system, always relying ion battery does not seem a good choice because the battery don´t provides 10 hours of real use as it says in the manual. And time to recharge the battery is too long.
In the manual they give you the option of using the XPS-DI box, but apparently Line6 has stopped manufacturing this box
This guitar so fantastic, when you use it live, or if you fancy a long study session with it constantly makes you be aware of the state of charge.
My question is: is there a chance to buy the XPS-DI box in Europe or Line6?.
Honestly, if I had known that these guitars only use batteries as main power source ...... I would not have bought, I thought Line6 still selling the XPS-DI box as an option.
It is assumed that a guitar is to give a very continuous use if you like, without having to monitor state of charge you have left.
a greeting
    Dec 22, 2006
    you can also power it with one of the pods.
  • edstar1960 Iknowathingortwo 712 posts since
    May 25, 2010
    Hi piratazo1,
    The DI box may be discontinued but you can still get it either on ebay as used or brand new from some stores:
    http://www.thomann.de/gb/line6_xps_mini_power_supply.htm
    You can also buy the A/B footswitch which was supplied as the power source for the first generation Variax, and these are available on ebay or from stores:
    http://www.dv247.com/guitars/line-6-variax-a-b-footswitch-pedal--41683
    Both of these will be able to power your JTV via a TRS cable into the normal 1/4" jack socket.
    Your other choices are buying a second Li-ion battery from Line6 or a Line6 dealer - I think you can order these now.
    Or the most expensive option is to use one of the POD's that has a Variax interface - but obviously this is not a good option if you already have a multi-fx/amp modeller unit from another vendor.
    My advice is to get one or two of the above power supplies while they are still available.
    Good luck!
    • sparkyERTW Just Startin' 271 posts since
      Feb 23, 2008
      Well, here's another thought: if you're not reaching anywhere near the 10 hours of battery life suggested, is it possible you've got a defective unit?  I can't say as mine hasn't arrived yet (argh!) and I don't know how short of 10 hours you're getting, but if you shared how off-the-mark it is, maybe someone can give you an idea if what you're seeing is signs of a flaw.
        May 25, 2010
        True - there have been reports of batteries draining even when the JTV is not plugged in.
        Remember to always unplug your JTV when not in use to maximise battery life.
        If you don't wish to always unplug it, then remember to turn the volume control down to zero as this will then put the JTV in a sleep mode after a minute - and this will also maximise battery usage.  (Although I have seen some reports from users who have said this also drained the battery for them).  I usually unplug mine and my battery seems to last for ages - I haven't actually tried it for 12 hours though as I usually power the guitar through the VDI from my X3L or my HD500.  I think the advertised maximum battery life for a fully charged battery (ie: one that has been left in the charger for an hour or so after the full charge light is on) in a JTV should be 12 hours.
      May 25, 2010
      Hello piratazo1,
      Just wondered why have you ordered a Variax Digital Cable?  This can only be used to power the guitar when connected to a Pod XTLive, X3Live or HD500. (BTW - It can also be used to swap guitar models remotely from the POD when swapping patches on the POD).
      To power the guitar from the A/B footswitch you need to order a balanced TRS jack to jack cable.  Effectively a stereo 1/4" jack to jack. These used to be supplied with the Variax 700 along with the A/B footswitch.
      The TRS cable runs from the JTV to the A/B box to get power and then you use a normal 1/4" jack or an XLR balanced lead out from the A/B box to either your guitar amp or direct to mixer/PA desk.
      If you already have a TRS jack to jack then you don't need to order one.
      Hope that helps!
          May 25, 2010
          Yes that is the type of cable I am referring to.
          It does not have to be that specific cable - there are many TRS jack to TRS jack cables available - some are much cheaper than that one.  You should buy the cable that is the quality and price point you are comfortable with.
          • JCJCJC Just Startin' 44 posts since
            Dec 6, 2006
            Hi There,
            It would appear that you have resolution on this, but if not, I have opened a ticket for you to have contact with me directly.
            Thanks
            JC
  • Rowbi Expert Line 6 User 7,745 posts since
    Nov 25, 2006
    I just wanted to clarify a few things in this thread that are incorrect...  Just in case someone in the future looks for the same info.
    The vdi cable doesn't use power over Ethernet, because its not using Ethernet, which is a networking protocol and nothing to do with the jtv guitars...  Yes it's a network cable, but a cable is only a bunch of wires to carry some data.  Line 6 use their own protocols over the wire.
    The xps mini I don't think is suitable for the jtv.  Only the xps-DI which is now discontinued, or it's replacement the xps a/b.  to use the a/b you will also need a stereo TRS cable no longer than 6m but shorter is fine, a standard guitar lead or XLR cable and lastly a line6 PX2 power supply to power it.  You will need Te px2 to be bought in your local region so the input voltage is correct.  The xps ab doesn't come with those cables and px2 though.
    Of course a POD with Variax connection and a VDI cable would work and give you extra features, but of you don't have one and don't need one then yes it's not a sensible Option.  But it's still an option for some, and for many people that's the desired option to get the most from the jtv.
    Perhaps another great idea would be getting spare batteries and a spare charger.  If you play a lot then you could always be charging a spare battery or two.  Andertons.co.uk just started listing the spare jtv batteries so they are becoming available.
    Hope this helps for clarification
    Rowbi
  • ScottPayer Just Startin' 5 posts since
    Jul 2, 2006
    I’m not looking for an answer, I’m just sharing my experience. I have read all the previous replies here.
    I found myself in the same predicament as the original poster. Yesterday I bought a brand new JTV-89 in the box from the local guitar center. The research I did ahead of time gave me the comfort of knowing I could still buy the XPS-DI since I will only use it at home as a hobbyist and am never that far from my gear. The reliability of having a regular power source was a key part of my purchase decision. Now when I actually go to look for the XPS-DI… well you know… you’ve all read the posts…
    Here are the mixed signals I get from the line 6 website after trying to figure out where to buy this thing. Please note the modified dates of the two pages.
    On the JTV FAQ page  (Modified date October 14th 2011), under the Battery section it says:
    “…Or, use the optional XPS-DI direct box/power supply and TRS cable.…”
    http://line6.com/support/docs/DOC-2322
    On another page under the XPS-DI answer for the Question “What is the XPS unit” (Modified date of Oct 28, 2009 9:51 AM) it says it was shipped with a Variax bass and describes how to use it but the very last sentence says: “Note:  This unit is no longer available as the Variax bass has been discontinued.”
    http://line6.com/support/docs/DOC-4699
    And today, December 13th 2011 I called Line 6 this morning, spoke with Hugo who transferred me to parts where I spoke with Neil. Neil told me they still have them in stock and I would have to do a special order from my dealer and he gave me the part number to use when I asked them to order it. The part # for the XPS-DI is 50-00-0148.
    BTW: MusiciansFriend told me they will not do special orders unless it’s over $100.00.
    I called my local guitar center and asked them to order it. He said he would call me as soon as they respond to his voicemail and let me know if he can confirm it can be shipped.
    Too much negative drama accompanying the purchase of this fantastic mix of music and technology. Kinda takes some of the joy out of it...
    I will post again when there is some sort of an end to this story.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
